Bluetooth, broken pipe exception when trying to send data with android
im not new to programming, but moderately new to java(not a fan) and brand new to android development(also not a fan). for testing right now im just trying to toggle a led on/off, but i get an exception thrown when it tries to send the data.
error: (i show which line the error is on in the java code) java.io.IOException: Broken pipe.
i printed out the socket as well previously and it was valid.
im using this
arduino: https://www.amazon.com/gp/product/B012FOV17O/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
bluetooth module: https://www.amazon.com/gp/product/B071YJG8DR/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
bluetooth module : arduino
RXD: RX1
TXD : TX0
GND : GND
VCC : VCC
arduino : other part of led/resistor
GND : led ground
2 : resistor : led positive
arduino code(taken from youtube as im trying to get this working asap before setting it up to do what i really want)
int LED_INPUT = 2;
  pinMode(LED_INPUT,OUTPUT);
  char data;
  if(Serial.available())
    data=Serial.read();
    if(data=='f')//LED ON
      digitalWrite(LED_INPUT,HIGH);
    if(data=='b')
      digitalWrite(LED_INPUT,LOW);
java code
public class MainActivity extends AppCompatActivity {
    Button i1;
    TextView t1;
    String address = null , name=null;
    BluetoothAdapter myBluetooth = null;
    BluetoothSocket btSocket = null;
    Set<BluetoothDevice> pairedDevices;
    static final UUID myUUID = UUID.fromString("00001101-0000-1000-8000-00805F9B34FB");
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        try {setw();} catch (Exception e) {}
        SetupOnRun();
    @SuppressLint("ClickableViewAccessibility")
    private void setw() throws IOException
        t1=(TextView)findViewById(R.id.TBBluetooth);
        bluetooth_connect_device();
        i1=(Button)findViewById(R.id.BToggleLight);
        i1.setOnTouchListener(new View.OnTouchListener()
        {   @Override
        public boolean onTouch(View v, MotionEvent event){
            if(event.getAction() == MotionEvent.ACTION_DOWN) {led_on_off("f");}
            if(event.getAction() == MotionEvent.ACTION_UP){led_on_off("b");}
            return true;}
    private void bluetooth_connect_device() throws IOException
        try
            myBluetooth = BluetoothAdapter.getDefaultAdapter();
            address = myBluetooth.getAddress();
            pairedDevices = myBluetooth.getBondedDevices();
            if (pairedDevices.size()>0)
                for(BluetoothDevice bt : pairedDevices)
                    address=bt.getAddress().toString();name = bt.getName().toString();
        catch(Exception we){t1.setText("first exception bluetooth_connected_device");}
        myBluetooth = BluetoothAdapter.getDefaultAdapter();//get the mobile bluetooth device
        BluetoothDevice dispositivo = myBluetooth.getRemoteDevice(address);//connects to the device's address and checks if it's available
        btSocket = dispositivo.createInsecureRfcommSocketToServiceRecord(myUUID);//create a RFCOMM (SPP) connection
        btSocket.connect();
        try { t1.setText("BT Name: "+name+"\nBT Address: "+address); }
        catch(Exception e){t1.setText("ISSUE bluetooth_connect_device");}
    private void led_on_off(String i)
        try
            if (btSocket!=null)
                btSocket.getOutputStream().write(i.getBytes());//heres where it goofs
            t1.setText("Success led_on_off");
        catch (Exception e)
            t1.setText("ERROR led_on_off: " + e);//HERES THE EXCEPTION THAT GETS PRINTED OUT
    public void SetupOnRun()
        SeekBar seekBar = (SeekBar) findViewById(R.id.SBSeekBar);
        TextView textBox = (TextView) findViewById(R.id.TBTest);
        ImageView bulb = (ImageView) findViewById(R.id.IMLightBulb);
        Button button = (Button) findViewById(R.id.BToggleLight);
        //seekBar.setForeground();
        int currentProgress = seekBar.getProgress();
        textBox.setText("Brightness: " + currentProgress + "%");
        bulb.setAlpha(currentProgress * 0.01f);
        button.setText("Off");
        SliderBarControl.StartSlider(seekBar, textBox, bulb, button);
    public boolean IsButtonOn(Button button)
        String buttonText = button.getText().toString();
        if (buttonText.equals("On"))
            return true;
            return false;
    public void TurnOffButton(Button button, SeekBar seekBar)
        seekBar.setProgress(0);
    public void TurnOnButton(Button button, SeekBar seekBar)
        button.setText("On");
        seekBar.setProgress(seekBar.getMax());
    public void ToggleButton(View v)
        if (IsButtonOn(button)) {
            t1.setText("OFF TEST");
            led_on_off("b");
            TurnOffButton(button, seekBar);
        else {
            t1.setText("ON TEST");
            led_on_off("f");
            TurnOnButton(button, seekBar);
if i missed some details let me know, i cant figure out where the issue is coming from
java(not a fan) and brand new to android development(also not a fan).......
setting it up to do what i really want)....
.......if i missed some details
This is an Arduino forum. I think, the bit you've missed is the bit that tells us what you really want to do with Arduino and plain-vanilla bluetooth. If you are not a fan of java, and not a fan of Android development, it seems that the only thing you want to do so far is bash your head against the wall, for no reward.
Nick_Pyner:
from reading about the exception thrown ive gathered its more likely related to the arduino/bluetooth module being closed off from the connection ive made. i switch between multiple languages pretty often for different tasks, java is just the one i personally dont like working with as much as something such as c# for regular development. what im trying to do right now is just make it so i can toggle the led thats connected to the arduino on/off from my android phone. im just trying to get the communication between the arduino and my phone working before continuing the project.
