Bluetooth button to start function with only button pressed.
Hi everyone, I am a new beginner with Arduino coding. Currently my project is to make a trash skimmer boat. I would like to control 4 DC motors by using bluetooth remote controller apps from phone. The Arduino UNO is connected to two motor drivers and each motor driver control two motors.
I have done the coding but now I would like to make the motors only run when button is pressed and stop running when button is without pressed from the apps. The bluetooth remote controller apps I use is with button (UP DOWN LEFT RIGHT CIRCLE CROSS TRIANGLE SQUARE). So any idea to solve my problem? :slight_smile:
Thank you.
#include<SoftwareSerial.h>
SoftwareSerial bt(2,4);//RX,TX
//LR Motor A
const int A1A = 6;
const int A1B = 9;
//FB Motor B
const int B1A = 3;
const int B1B = 5;
//Handling Motor C
const int C1A = 10;
const int C1B = 11;
//Handling Motor D
const int D1A = 12;
const int D1B = 13;
int state = 0;
  pinMode(B1A,OUTPUT);// define pin as output
  pinMode(B1B,OUTPUT);
  pinMode(A1A,OUTPUT);
  pinMode(A1B,OUTPUT);
  pinMode(C1A,OUTPUT);
  pinMode(C1B,OUTPUT);
  pinMode(D1A,OUTPUT);
  pinMode(D1B,OUTPUT);
  delay(3000);
  bt.begin(9600); // Default connection rate for my BT module
  if(bt.available() > 0)
      state = (bt.read());
  if(state =='F')//Forward
    digitalWrite(A1A,LOW);
    digitalWrite(A1B,HIGH);
  else if (state =='B')//Backward
    digitalWrite(A1A,HIGH);
    digitalWrite(A1B,LOW);
  else if(state =='R')//Right
      digitalWrite(B1A,LOW);
      digitalWrite(B1B,HIGH);
  else if(state =='L')//Left
      digitalWrite(B1A,HIGH);
      digitalWrite(B1B,LOW);
  else if(state =='U')// LIFT UP ARM
      digitalWrite(C1A,LOW);
      digitalWrite(C1B,HIGH);
      digitalWrite(D1A,LOW);
      digitalWrite(D1B,HIGH);
  else if(state =='D')// LIFT DOWN ARM
      digitalWrite(C1A,HIGH);
      digitalWrite(C1B,LOW);
      digitalWrite(D1A,HIGH);
      digitalWrite(D1B,LOW);
motor_driver.ino (1.76 KB)
The OPs code posted in the preferred way
SoftwareSerial bt(2, 4); //RX,TX
//LR Motor A
const int A1A = 6;
const int A1B = 9;
//FB Motor B
const int B1A = 3;
const int B1B = 5;
//Handling Motor C
const int C1A = 10;
const int C1B = 11;
//Handling Motor D
const int D1A = 12;
const int D1B = 13;
int state = 0;
  pinMode(B1A, OUTPUT); // define pin as output
  pinMode(B1B, OUTPUT);
  pinMode(A1A, OUTPUT);
  pinMode(A1B, OUTPUT);
  pinMode(C1A, OUTPUT);
  pinMode(C1B, OUTPUT);
  pinMode(D1A, OUTPUT);
  pinMode(D1B, OUTPUT);
  delay(3000);
  if (bt.available() > 0)
  if (state == 'F') //Forward
    digitalWrite(A1A, LOW);
    digitalWrite(A1B, HIGH);
  else if (state == 'B') //Backward
    digitalWrite(A1A, HIGH);
    digitalWrite(A1B, LOW);
  else if (state == 'R') //Right
    digitalWrite(B1A, LOW);
    digitalWrite(B1B, HIGH);
  else if (state == 'L') //Left
    digitalWrite(B1A, HIGH);
    digitalWrite(B1B, LOW);
  else if (state == 'U') // LIFT UP ARM
    digitalWrite(C1A, LOW);
    digitalWrite(C1B, HIGH);
    digitalWrite(D1A, LOW);
    digitalWrite(D1B, HIGH);
  else if (state == 'D') // LIFT DOWN ARM
    digitalWrite(C1A, HIGH);
    digitalWrite(C1B, LOW);
    digitalWrite(D1A, HIGH);
    digitalWrite(D1B, LOW);
@zeroyiq - not that the code has been Auto formatted in the IDE and posted using code tags
See Read this before posting a programming question
