Since you did not bother to post your code I do not see how we can tell you "which lines should I add to my code please ?"
Here is example code to read the Bluetooth serial port and turn on the onboard LED (pin 13 on Uno, Nano, Mega). Send "led on" (no quotes) to turn the LED on and "led off" to turn the LED off. This code uses example 2 method from the serial input basics tutorial and the strcmp() function. The data from the sender must be terminated with a line feed character (0x0a, '\n').
#include <SoftwareSerial.h>
SoftwareSerial bt(4, 5); // RX | TX
const byte numChars = 16;
char receivedChars[numChars]; // an array to store the received data
const byte ledPin = 13;
boolean newData = false;
Serial.begin(38400); // ****** set serial monitor to this baud rate
bt.begin(38400); // ******* insert the baud rate for your BT module (usual default is 9600)
Serial.println("<Arduino is ready>");
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
recvWithEndMarker();
if (newData == true)
Serial.println(receivedChars);
if (strcmp(receivedChars, "led on") == 0)
digitalWrite(ledPin, HIGH);
if (strcmp(receivedChars, "led off")== 0)
newData = false;
void recvWithEndMarker()
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (bt.available() > 0 && newData == false)
rc = bt.read();
//Serial.print(rc);
if (rc == '\r')
return;
if (rc != endMarker)
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars)
ndx = numChars - 1;
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
Assuming your bluetooth module is connected via serial this code will respond to on and off commands
Control Led via bluetooth
Assume bluetooth via serial like https://www.forward.com.au/pfod/BLE/index.html#Adafruit
#include "SafeString.h" // my SafeString library from the Arduino library manager
char onCmd[] = "on";
char offCmd[] = "off";
char delimiters[] = " \r\n"; // space CR NL are cmd delimiters or accept after 2sec
const size_t maxCmdLength = 5; // length of largest command to be recognized, can handle longer input but will not tokenize it.
createSafeString(input, maxCmdLength + 1); // to read input cmd, large enough to hold longest cmd + leading and trailing delimiters
createSafeString(token, maxCmdLength + 1); // for parsing, capacity should be >= input
bool skipToDelimiter = true; // bool variable to hold the skipToDelimiter state across calls to readUntilToken()
// set skipToDelimiter = true to skip initial data upto first delimiter.
// skipToDelimiter = true can be set at any time to next delimiter.
unsigned long TIMEOUT_MS = 2000; // 2sec
// assuming you bluetooth is connected via Serial
Serial.begin(9600); // Open serial communications and wait a few seconds
for (int i = 10; i > 0; i--) {
// first run without any outputting any error msgs or debugging
//SafeString::setOutput(Serial); // enable error messages and debug() output to be sent to Serial
void handleonCmd() {
// turn led On here
void handleoffCmd() {
// turn led Off hereSerial.println(); Serial.println(F(" Found offCmd"));
if (input.readUntilToken(Serial, token, delimiters, skipToDelimiter, false, TIMEOUT_MS )) {
// use false to suppress echo of input, back to bluetooth
if (token == onCmd) {
handleonCmd();
} else if (token == offCmd) {
handleoffCmd();
} // else token is empty
// rest of code here if any
You don't need to send a \r or \n the command will be accepted after 2sec. All other words will be ignored
good example code. Nevertheless I want to post a version with a minor change
you named the SafeString-variables "Input" and "token". especcially the word "input" is so general that it might be hard to understand for newbees what it really is.
So I renamed then to "myInputStr" and "myTokenStr" to indicate through the prefix "my" it is a user-choosable name and the suffix "Str" to indicate it is SafeString-variable.
createSafeString(myInputStr, maxCmdLength + 1); // to read input cmd, large enough to hold longest cmd + leading and trailing delimiters
createSafeString(myTokenStr, maxCmdLength + 1); // for parsing, capacity should be >= myInputStr
// assuming your bluetooth is connected via Serial
// turn led On here
if (myInputStr.readUntilToken(Serial, myTokenStr, delimiters, skipToDelimiter, false, TIMEOUT_MS )) {
if (myTokenStr == onCmd) {
handleonCmd();
} else if (myTokenStr == offCmd) {
handleoffCmd();
} // else myTokenStr is empty
what your post does not explain is what kind of character-sequence has to be send to make it work
Hi all
thanks for your feedback
here's the code I'm using :
#include <SoftwareSerial.h> //Software Serial Port
#define RxD 7 // sur le module jumper TX sur 6
#define TxD 6 //sur le module jumper RX sur 7
#define DEBUG_ENABLED 1
SoftwareSerial blueToothSerial(RxD,TxD);
pinMode(RxD, INPUT);
pinMode(TxD, OUTPUT);
setupBlueToothConnection();
char recvChar;
while(1)
if(blueToothSerial.available())
recvChar = blueToothSerial.read();
Serial.print(recvChar);
if(Serial.available())
recvChar = Serial.read();
blueToothSerial.print(recvChar);
void setupBlueToothConnection()
blueToothSerial.begin(9600); // Set BluetoothBee BaudRate to default baud rate 38400
blueToothSerial.print("\r\n+STWMOD=0\r\n"); // set the bluetooth work in slave mode
blueToothSerial.print("\r\n+STNA=SeeedBTSlave\r\n"); // set the bluetooth name as "SeeedBTSlave"
blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto connection should be forbidden here
delay(2000); // This delay is required
Serial.print("\r\n+INQ=1\r\n"); // make the slave bluetooth inquirable
Serial.println("The slave bluetooth is inquirable!");
delay(2000); // This delay is required.
blueToothSerial.flush();
But ... is there some library conflict if I want to add a servo to my code
What leads you to believe that?
bluetooth_led:24:1: error: 'recvWithEndMarker' was not declared in this scope
You should post the code that causes the error. My guess is that there is a curly bracket (}) missing to close the loop() function. Use the IDE autoformat tool (ctrl-t or Tools, Auto Format) and you might see where the problem is.
If that is not it, post the code.
And please post the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
groundFungus:
Thanks, you were right (a missing curly bracket)
Best regards
