Bluetooth Communication Only Working with RX On Pin 13
I am using a Bluetooth mate with an Arduino Mega 2560 and finding that the Mega is only receiving serial communication when I use pin 13 for RX which is connected to TX-0 on the mate. I am trying to determine why this is occurring since the documentation indicates I should be able to use pins like 15,17, or 19 for RX.
I can use different pins on the mega for TX without issue. When it's working I see the TX LED on the Mega blink when I send a message, but when not on pin 13 I get nothing. My code is below:
#include <SoftwareSerial.h>
int bluetoothTx = 13;  // RX-I pin of bluetooth mate connects to TX of Arduino
int bluetoothRx =22;  // TX-O pin of bluetooth mate connects to RX of Arduino
String bluetoothMsg = "";
SoftwareSerial bluetooth(bluetoothTx,bluetoothRx);
  Serial.begin(9600);  // Begin the serial monitor at 9600bps
  bluetooth.begin(115200);  // The Bluetooth Mate defaults to 115200bps
  bluetooth.print("$");  // Print three times individually
  bluetooth.print("$");  // Enter command mode
  delay(100);  // Short delay, wait for the Mate to send back CMD
  bluetooth.println("U,9600,N");  // Temporarily Change the baudrate to 9600, no parity
  // 115200 can be too fast at times for NewSoftSerial to relay the data reliably
  bluetooth.begin(9600);  // Start bluetooth serial at 9600
  bluetooth.listen();
  if(bluetooth.available())  // If the bluetooth sent any characters
      // Read the char
      char newChar = (char)bluetooth.read();
      // Append the chart to the string
      if(newChar == '^')
        Serial.print(bluetoothMsg);
      else if(newChar == '~')
        bluetoothMsg = "";
        bluetoothMsg += newChar;
Why do you need to use Software Serial on an Arduino Mega as it has 4 UARTS on it already?
Can you post a schematic of whatever it is you are making?
And the use of Strings, is a waste of memory. Look into C strings (char arrays)
Thanks, I did some more reading and tried "Serial3" with pins 14 & 15 and that worked. This seems like a better option than SoftwareSerial. I will also check out using char arrays instead of Strings.
You may find some useful ideas in Serial Input Basics
...R
