Hi
I have an arduino code for communicating with bluetooth module HC-05
the arduino code is
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("Ready!");
// set the data rate for the SoftwareSerial port
// for HC-05 use 38400 when poerwing with KEY/STATE set to HIGH on power on
mySerial.begin(9600);
void loop() // run over and over
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
hardware connection of bluetooth module
vcc => 5v
TXD => 10
RXD => 11
GND
Arduino code is not shown error it will uploaded to arduino yun successfully but in serial monitor i send "AT" command means it doesn't replay "OK"
