Bluetooth communications
Hi all,
I have been using Arduino nano 33 ble sense and ccs811 air quality sensor to measure temperature humidity, pressure , eco2 and tvoc. Now I want to send these details to app using bluetooth. Can the bluetooth in nano 33 ble sense be used to send data or do I need use external bluetooth like hc-05 or 06 module??
Thanks in advance
Yes.
No, you do not need a external module.
Here is an example that implements the Environmental Sensing Service specified by the Bluetooth SIG on the Arduino Nano 33 BLE Sense.
  This example creates a BLE peripheral with a Environmental Sensing Service (ESS)
  that contains a temperature, humidity and pressure characteristic.
  The yellow LED shows the BLE module is connected to a central.
  The circuit:
  - Arduino Nano 33 BLE Sense
  You can use a generic BLE central app, like BLE Scanner (iOS and Android) or
  nRF Connect, to interact with the services and characteristics
  created in this sketch.
  This example code is in the public domain.
#include <ArduinoBLE.h>
#include <Arduino_HTS221.h>
#include <Arduino_LPS22HB.h>
// BLE UUIDs
// https://www.bluetooth.com/specifications/assigned-numbers/environmental-sensing-service-characteristics/
// https://www.bluetooth.com/wp-content/uploads/Sitecore-Media-Library/Gatt/Xml/Characteristics/org.bluetooth.characteristic.temperature.xml
// https://www.bluetooth.com/wp-content/uploads/Sitecore-Media-Library/Gatt/Xml/Characteristics/org.bluetooth.characteristic.humidity.xml
// https://www.bluetooth.com/wp-content/uploads/Sitecore-Media-Library/Gatt/Xml/Characteristics/org.bluetooth.characteristic.pressure.xml
#define BLE_UUID_ENVIRONMENTAL_SENSING_SERVICE    "181A"
#define BLE_UUID_TEMPERATURE                      "2A6E"
#define BLE_UUID_HUMIDITY                         "2A6F"
#define BLE_UUID_PRESSURE                         "2A6D"
// BLE
#define BLE_DEVICE_NAME                           "Arduino Nano 33 BLE"
#define BLE_LOCAL_NAME                            "Arduino Nano 33 BLE"
BLEService environmentalSensingService( BLE_UUID_ENVIRONMENTAL_SENSING_SERVICE );
BLEShortCharacteristic temperatureCharacteristic( BLE_UUID_TEMPERATURE, BLERead | BLENotify );
BLEUnsignedShortCharacteristic humidityCharacteristic( BLE_UUID_HUMIDITY, BLERead | BLENotify );
BLEUnsignedLongCharacteristic pressureCharacteristic( BLE_UUID_PRESSURE, BLERead | BLENotify );
// APP & I/O
#define SENSOR_UPDATE_INTERVAL                    (5000)
typedef struct __attribute__( ( packed ) )
  float temperature;
  float humidity;
  float pressure;
  bool updated = false;
} sensor_data_t;
sensor_data_t sensorData;
#define BLE_LED_PIN                               LED_BUILTIN
  Serial.begin( 9600 );
  while ( !Serial );
  Serial.println( "BLE Example - Environmental Sensing Service (ESS)" );
  pinMode( BLE_LED_PIN, OUTPUT );
  digitalWrite( BLE_LED_PIN, LOW );
  // Without Serial when using USB power bank HTS sensor seems to needs some time for setup
  delay( 10 );
  if ( !HTS.begin() )
    Serial.println( "Failed to initialize humidity temperature sensor!" );
    while ( 1 );
  if ( !BARO.begin() )
    Serial.println( "Failed to initialize pressure sensor!" );
    while ( 1 );
  if ( !setupBleMode() )
    Serial.println( "Failed to initialize BLE!" );
    while ( 1 );
    Serial.println( "BLE initialized. Waiting for clients to connect." );
  bleTask();
  if ( sensorTask() )
    printTask();
bool sensorTask()
  static uint32_t previousMillis = 0;
  uint32_t currentMillis = millis();
  if ( currentMillis - previousMillis < SENSOR_UPDATE_INTERVAL )
    return false;
  sensorData.temperature = HTS.readTemperature();
  sensorData.humidity = HTS.readHumidity();
  sensorData.pressure = BARO.readPressure() * 1000; // kPa -> Pa
  sensorData.updated = true;
  return sensorData.updated;
void printTask()
  Serial.print( "Temperature = " );
  Serial.print( sensorData.temperature );
  Serial.println( " °C" );
  Serial.print( "Humidity    = " );
  Serial.print( sensorData.humidity );
  Serial.println( " %" );
  Serial.print( "Pressure = " );
  Serial.print( sensorData.pressure );
  Serial.println( " Pa" );
bool setupBleMode()
  if ( !BLE.begin() )
    return false;
  // set advertised local name and service UUID
  BLE.setDeviceName( BLE_DEVICE_NAME );
  BLE.setLocalName( BLE_LOCAL_NAME );
  BLE.setAdvertisedService( environmentalSensingService );
  // BLE add characteristics
  environmentalSensingService.addCharacteristic( temperatureCharacteristic );
  environmentalSensingService.addCharacteristic( humidityCharacteristic );
  environmentalSensingService.addCharacteristic( pressureCharacteristic );
  // add service
  BLE.addService( environmentalSensingService );
  // set the initial value for the characeristic
  temperatureCharacteristic.writeValue( 0 );
  humidityCharacteristic.writeValue( 0 );
  pressureCharacteristic.writeValue( 0 );
  // set BLE event handlers
  BLE.setEventHandler( BLEConnected, blePeripheralConnectHandler );
  BLE.setEventHandler( BLEDisconnected, blePeripheralDisconnectHandler );
  // start advertising
  BLE.advertise();
  return true;
void bleTask()
  const uint32_t BLE_UPDATE_INTERVAL = 10;
  if ( currentMillis - previousMillis >= BLE_UPDATE_INTERVAL )
    BLE.poll();
  if ( sensorData.updated )
    // BLE defines Temperature UUID 2A6E Type sint16 ( see XML links )
    // Unit is in degrees Celsius with a resolution of 0.01 degrees Celsius
    int16_t temperature = round( sensorData.temperature * 100.0 );
    temperatureCharacteristic.writeValue( temperature );
    // BLE defines Humidity UUID 2A6F Type uint16
    // Unit is in percent with a resolution of 0.01 percent
    uint16_t humidity = round( sensorData.humidity * 100.0 );
    humidityCharacteristic.writeValue( humidity );
    // BLE defines Pressure UUID 2A6D Type uint32
    // Unit is in Pascal with a resolution of 0.1 Pa
    uint32_t pressure = round( sensorData.pressure * 10.0 );
    pressureCharacteristic.writeValue( pressure );
    sensorData.updated = false;
void blePeripheralConnectHandler( BLEDevice central )
  digitalWrite( BLE_LED_PIN, HIGH );
  Serial.print( F ( "Connected to central: " ) );
  Serial.println( central.address() );
void blePeripheralDisconnectHandler( BLEDevice central )
  Serial.print( F( "Disconnected from central: " ) );
The nano 33 BLE comes with bluetooth module as part of the board. For more details on the board and its capabilities, you can have a look at the Docs page.
Nano 33 BLE: https://docs.arduino.cc/hardware/nano-33-ble
