Hello ,
wanted to know if I can do the following:
I want to connect 3 bluetooth headphones to a ardiuno , so all 3 will be able to talk at the same time
so as they connect the "line" will be open and they can talk and listen at the same time
can it be done on the Arduno ? or at all ?
Thanks ,
No, and no. You can probably do what you want to do but, when you do it, it probably won't need an Arduino and certainly won't use bluetooth.
OK
why?
because Bluetooth is only 1 device to 1 device?
and how do you suggest I wil do this?
Thanks ,
david1234:
Correct.
I haven't the faintest idea how you would do this. I imagine it is some full-duplex radio network.
OK
I thought maybe there is something I don't know \ missing
Thank you
david1234:
OK
Thank you
And if it was possible, how would you propose to control the communications?
Paul
I don;t know
this is why I ask here if someone know something
