I'm very new to Bluetooth with the arduino and need to send data from an analog sensing circuit to the arduino using 2 RN-42s. I have read lots of posts, blogs and videos and it's still not fully clear to me.
The setup:
1 arduino + 1 ATtiny microcontroller (couldn't afford a second arduino for this)
2 RN-42 XV
1 Analog circuit - LED and photodiode
The ATtiny will monitor the input, transmit it to the arduino
The arduino will receive the transmitted data and display it on the serial monitor.
Any help will be very much appreciated!
Below is the code i have so far:
int sense = 0; //sensing analog value (actually from 0 - 5V)
int pulse = 13; //pulse with input
int tx = 2; // transmit
SoftwareSerial bluetooth(tx); //just transmit input
pinMode(sense,INPUT);
pinMode(pulse,OUTPUT);
bluetooth.println(analogRead(0)); //print the detected value
delay (100);
bluetooth.begin(115200);
if (Serial.available() > 900) //expecting analog signal to vary between 0 - 1023
char data = Serial.read(); //read if data available, store in data
Serial.println(data); // display sensed value
delay (100);
println 'ing before you even initialized the bluetooth software port! wrong! swap these statements.
make the it(Serial.available() > 0){}
essentially you are making the pin number 0 that is the RX input so how'll you now receive anything?
int sense = 1; //sensing analog value (actually from 0 - 5V)
//int check = 0;//flag to check status of input
delay (100);
if (Serial.available() > 0) //expecting signal to vary between 0 - 1023
Am i on track? I just need to read the analog value in the receive pin and transmit it - to another RN42
My issue is trying to transmit it - so it appears on the Bluetooth COM Port. At the moment it doesn't
You have the code for one uC and you have told that its for Arduino or the ATtiny?
so give the other set of code that you have for either of the Arduino or ATtiney!
secondly I'm still not getting what exactly you want? I mean you want to receive the info using the bluetooth on the arduino from the ATtiny and then on the Arduino COM port show what you got over bluetooth?
so you mean you have the serial connections of the RN42 hooked to the USB port directly?
and connecting to it using somehting which has the bluetooth like the android ?
OR
you have connected the RN42 to the arduino and then the arduino is connected to the computer and using the com port as such created to read the input?
OK connection ideology is fine! (dont know whether you connected all that right?)
so how you expect the RN42 to get anything? I mean you need to send to it or read from it only when the bluetooth is paired to some phone and a serial link has been successfully establish and you use an app like the bluetooth chat available for android, if you have not paried any thing to the bluetooth hence not sending anything to it.
Oh the Bluetooth only sends when paired? Not continuous transmission like radio - till you tune in to it?
You need to pair it PERIOD
(whether its bluetooth supporting embedded system to another bluetooth supporting embeded system or a bluetooh supported computer or phone)
then based on the profiles supported by the bluetooth module its stack works! in your case its the SPP profile.
Codewise I already told you to make ammendments so just try now ,just worry about the logic levels that is RN42 is 3.3v and the atmega should be 3.3v level too! else use a logic level converter. also connect everything correctly.
I was hoping i could simply upload my arduino code to the ATtiny - NOT the case.
I have already tested and coded within the Arduino IDE 0022/1.0 for ATtiny85 and used UART too that to successfully with the 9600baud rate to and fro info. from a bluetooth module, so it works all fine.
and since then did a lot many times!
You have to use software serial library for this and also ,go search for MIT labs attiny85 on google if you havent get going with their suggestions at first.
Hi, thanks for the reply. I'm understanding this a bit better now.
I decided to achieve basics first - turning an LED on and off through bluetooth with my laptop and the ATtiny.
heres a sample code i have modified:
#include <SoftwareSerial.h>
int rx = 1; //recieve to 1
int tx = 2; // transmit to pin 2
SoftwareSerial blueToothSerial(rx,tx);
int led = 0;
pinMode(rx, INPUT);
pinMode(tx, OUTPUT);
setupBlueToothConnection();
pinMode(led,OUTPUT);
digitalWrite(led,HIGH); //initialising LED state
char recvChar; //check if data sent from bluetooth
if (blueToothSerial.available())//if data available, read!
recvChar = blueToothSerial.read(); //received character
if(recvChar == 'a')
digitalWrite(led,LOW);
else if(recvChar =='b')
//delay(1000);
//delay(1000);
blueToothSerial.flush();
void setupBlueToothConnection()
blueToothSerial.begin(115200);//default baud rate
blueToothSerial.print("\r\n+STWMOD=0\r\n");//slave mode BT
blueToothSerial.print("\r\n+STNA=RN42\r\n");//set name
blueToothSerial.print("\r\n+STOAUT=1\r\n");//permit connection
blueToothSerial.print("\r\n+STAUTO=0\r\n");//Auto-connection
//delay(2000);//required delay
//blueToothSerial.print("\r\n+INQ=1\r\n"); //BT is inquirable
blueToothSerial.println("Praise God, Connected!\n");
The problem with this is that the LED (connected to the ATtiny) always turns off regardless of what character is pressed - and stays off. I am sending characters through the serial monitor on the arduino IDE
int led = 0;
pinMode(rx, INPUT);
Well that is wrong! you just don't need to set the pinMode for the uart pins just use the pins you want to implement UART on in the constructer and thats all!, who told you to do pinMode on software serial pins?
Sample code for ATtiny85 that works:
SoftwareSerial mySerial(3, 4);
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
pinMode(0, OUTPUT);
mySerial.println("Hello, world?");
void loop() // run over and over
if(mySerial.available() > 0) {
char input = mySerial.read();
if (input == 'n') {
mySerial.println("N was there");
digitalWrite(0, 1);
if (input == 'a') {
mySerial.println("A was there");
digitalWrite(0, 0);
