bluetooth control car
hello, my robot actually can connect to mobile phone and able to communicate but the motor l289n giving noice and its not moving. is there any solution . the code is below
/* define section */
//Motor driver setup L298N
const int IN1 = 7; //connect IN1 in the motor driver to pin number 7 in arduino
const int IN2 = 6; //connect IN2 in the motor driver to pin number 6 in arduino
const int IN3 = 5; //connect IN3 in the motor driver to pin number 5 in arduino
const int IN4 = 4; //connect IN4 in the motor driver to pin number 4 in arduino
/* this will allow you to control the speed of the motors */
const int ENA = 9; //connect IN1 in the motor driver to pin number 9 in arduino
const int ENB = 3; //connect IN1 in the motor driver to pin number 3 in arduino
int command = 0;// int to store the data that we will receive from the bluetooth
/* define the pins for the ultrasonic sensor */
int trig = 11; /* connect trigger pin of Ultrasonic to pin number 11 /
int echo = 12; /
connect echo pin of Ultrasonic to pin number 12 */
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
// set motor driver`s pins to output
pinMode (IN1, OUTPUT);
pinMode (IN2, OUTPUT);
pinMode (IN3, OUTPUT);
pinMode (IN4, OUTPUT);
pinMode (ENA, OUTPUT);
pinMode (ENB, OUTPUT);
//set trig pin as output and the echo pin as input for the ultrasonic sesor
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
if (Serial.available() > 0) //check if the arduino is receiving data or not
command=Serial.read();
if (command == ‘0’)//if we receive a character 0 then both motors will move forward
digitalWrite(IN1, LOW);
digitalWrite(IN2, HIGH);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
analogWrite(ENA, 50);
analogWrite(ENB, 50);
Serial.println(“go forward!”);
command=0; //set command value back to 0
else if(command == ‘1’) // moving backward
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW);
digitalWrite(IN3, HIGH);
digitalWrite(IN4, LOW);
else if (command == ‘2’) //moving left
else if (command == ‘3’) //moving right
else if (command == ‘4’) //stop the motors
else if (command == ‘5’)
long du = 0, ds = 0; // Transmitting pulse
digitalWrite(trig, LOW); //set trig pin to high
delayMicroseconds(10); //wait 2MS
digitalWrite(trig, HIGH); //set trig pin to high to send pulse
delayMicroseconds(10); //wait 10MS
digitalWrite(trig, LOW);// Waiting for pulse
du = pulseIn(echo, HIGH);// check for the pulse
ds = du*0.034/2 ;// Calculating distance
//move the motors forward
if (ds<=10) //if the space betwen the robot and the object less than 10 or 10 then turn right until the robot gets a space more than 10
command=‘5’; //here we will let the robot do the same job untill the we press stop bottom from mobile or press any bottom so we control it manualy
did you try changing
to
analogWrite(ENA, 255); // full speed
analogWrite(ENB, 255);
to see if the motors then run?
likely cause for your the motors to make 'noise' only is that it's not getting enough power from its supply OR the PWM is to low
hope that helps...
