bluetooth controlled lawn mower
OK, quick explanation, my goal is to contol my lawn mower from inside using a usb gamepad on my computer.
I have a dual motor controller that can be hooked up to the arduino with no problem.
I have an arduino uno already and I am looking for a bluetooth shield(would like suggestions for a class 1 bluetooth shield)
I have already selected a high voltage relay to turn on and off the blade motor (when i hold down a button and it will cuts off once i let go of the button)
What I am looking for help with is questions with programming, I can already program the arduino to move the motors and motor controllers by pretending its 2 servos.
My issue is...
How to I make a user interface that will allow me to plug a game pad into my PC and control the arduino via bluetooth
I know I would map my analog controls x and y axis with numbers from 0-255 to reflect with the servos but how do I send that to the arduino??
any examples would be great
any if anyone has already made program that would be awesome to get the source code.
I plan to have 4 webcams connected via a Raspberry Pi and I already have that setup and will have the streaming videos linked to this program.
Start wired. Can you make the mower change direction in response to the game controller? Only when that is working perfectly should you attempt wireless control, at which time it will be trivial.
