Bluetooth controlled RC car with a l298n
I made an RC car that was controlled with a phone, but I have a little problem. It was working without the ENA pins. But when I added the ENA pins is stops working. I found out that the problem is with Bluetooth. Because it connects to my phone but it doesn't send data. When I remove
pinMode(pmwa, OUTPUT);
  pinMode(pmwb, OUTPUT);
It works again but I didn't come up with how I Can fix it. This is the code
#include <SoftwareSerial.h>
#define RxD 6
#define TxD 7
#define in1 9
#define in2 8
#define in3 10
#define in4 11
#define pmwa 5
#define pmwb 6
SoftwareSerial blueToothSerial(RxD,TxD);
  pinMode(RxD, INPUT);
  pinMode(TxD, OUTPUT);
  setupBlueToothConnection();
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  char recvChar;
  while(1){
    if(blueToothSerial.available()){//check if there's any data sent from the remote bluetooth shield
      recvChar = blueToothSerial.read();
      Serial.print(recvChar);
    if(Serial.available()){//check if there's any data sent from the local serial terminal, you can add the other applications here
      recvChar  = Serial.read();
      blueToothSerial.print(recvChar);
     if (recvChar == 'F'){
      forward();
     else if (recvChar == 'S'){
      off();
     else if (recvChar == 'L'){
      left();
     else if (recvChar == 'R'){
      right();
     else if (recvChar == 'G'){
      back();
     else if (recvChar == 'Q'){
      leftfor();
     else if (recvChar == 'E'){
      rightfor();
     else if (recvChar == 'Z'){
      leftback();
     else if (recvChar == 'C'){
      rightback();
     delay(100);
void setupBlueToothConnection()
  blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
  blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
  blueToothSerial.print("\r\n+STNA=CrowBTSlave\r\n"); //set the bluetooth name as "CrowBTSlave"
  blueToothSerial.print("\r\n+STPIN=0000\r\n");//Set SLAVE pincode"0000"
  blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
  blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
  delay(2000); // This delay is required.
  blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
  Serial.println("The slave bluetooth is inquirable!");
  blueToothSerial.flush();
void forward(){
  digitalWrite(in1, HIGH);
  digitalWrite(in2, LOW);
  analogWrite(pmwa, 250);
  digitalWrite(in3, HIGH);
  digitalWrite(in4, LOW);
  analogWrite(pmwb, 250);
void off(){
  digitalWrite(in1, LOW);
  analogWrite(pmwa, 0);
  digitalWrite(in3, LOW);
  analogWrite(pmwb, 0);
void left(){
  analogWrite(pmwa, 150);
  digitalWrite(in4, HIGH);
  analogWrite(pmwb, 150);
void right(){
  digitalWrite(in2, HIGH);
void back(){
  analogWrite(pmwa, 200);
  analogWrite(pmwb, 200);
void leftfor(){
void rightfor(){
void leftback(){
void rightback(){
Can you help me? Thanks
#define RxD 6
#define pmwb 6
Doesn't seem like a good idea.
Steve
I am so stupid. but thx
#define RxD 6
ya, RxD and pwmb have a same number, change it.
Goodluck,
cheers,
niel.
But HEY! Your first post showed proper use of code tags! Karma++
