Thanks for the feedback and I apologize for the confusion on my part, please ignore my first comment.
Basically, I will like to control two servo motors with a Wii Nunchuck controller, and I have a few questions regarding it:
Two sets of data will be sent constantly from the Wii Nunchuck Side to the Servo Motor Side, let's call them x & y respectively. The x & y values are sent in without delay so they are in pretty large quantity. On the servo side, I only know how to display ALL the data that are being received. However, what I want to know is how to assign value x to Servo1 and value y to Servo2, before commanding the servos to execute the assigned values.
While attempting to control one servo via the method mentioned above, the servo was just swinging back and forth randomly despite that the x values are being received on the servo side and executed properly. Hence I am not sure if the idea of using Bluetooth + SoftwareSerial along with Servo works and will like to clarify if the idea is viable as I have read somewhere that The SoftwareSerial and Servo libraries conflict with each other.
Wii Nunchuck Side Connections (Transmitter)
HC-12 > Arduino Nano
VCC > 5V
GND > GND
TX > D10
RX > D11
Wii Nunchuk Adapter > Arduino Nano
- (VCC) > VCC
d > A4
c > A5
Servo Motor Side (Receiver)
Servo 1 & 2 > Arduino Nano
VCC > VCC
GND > GND
Servo1 output > D9
Servo2 output > D10
**HC-12 > Arduino Nano **
VCC > 5V
GND > GND
TX > D2
RX > D3
Wii Nunchuck Side Code[/b]
**[u]#include <Wire.h>
#include <SoftwareSerial.h>
SoftwareSerial Wireless_Serial (10,11); //Rx | Tx
static uint8_t nunchuck_buf[6]; // array to store nunchuck data,
Wireless_Serial.begin(9600);
nunchuck_setpowerpins(); // use analog pins 2&3 as fake gnd & pwr
nunchuck_init(); // send the initilization handshake
Serial.print ("Finished setup\n");
nunchuck_get_data();
// map nunchuk data to a servo data point
int x_axis = map(nunchuck_buf[0], 23, 222, 180, 0);
int y_axis = map(nunchuck_buf[1], 32, 231, 0, 180);
//move servo to desired position based on Wii nunchuk reading
Wireless_Serial.print(x_axis);
//Wireless_Serial.print(y_axis);
// un-comment next line to print data to serial monitor
// nunchuck_print_data();
if (Serial.available())
Wireless_Serial.write(Serial.read());
// Nunchuck functions
// Uses port C (analog in) pins as power & ground for Nunchuck
static void nunchuck_setpowerpins()
#define pwrpin PORTC3
#define gndpin PORTC2
DDRC |= _BV(pwrpin) | _BV(gndpin);
PORTC &=~ _BV(gndpin);
PORTC |= _BV(pwrpin);
delay(100); // wait for things to stabilize
// initialize the I2C system, join the I2C bus,
// and tell the nunchuck we're talking to it
void nunchuck_init()
Wire.begin(); // join i2c bus as master
Wire.beginTransmission(0x52); // transmit to device 0x52
Wire.write(0x40); // sends memory address
Wire.write(0x00); // sends sent a zero.
Wire.endTransmission(); // stop transmitting
// Send a request for data to the nunchuck
// was "send_zero()"
void nunchuck_send_request()
Wire.write(0x00); // sends one byte
// Receive data back from the nunchuck,
int nunchuck_get_data()
int cnt=0;
Wire.requestFrom (0x52, 6); // request data from nunchuck
while (Wire.available ()) {
// receive byte as an integer
nunchuck_buf[cnt] = nunchuk_decode_byte(Wire.read());
cnt++;
nunchuck_send_request(); // send request for next data payload
// If we recieved the 6 bytes, then go print them
if (cnt >= 5) {
return 1; // success
return 0; //failure
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits. That is why I
// multiply them by 2 * 2
void nunchuck_print_data()
static int i=0;
int joy_x_axis = nunchuck_buf[0];
int joy_y_axis = nunchuck_buf[1];
int accel_x_axis = nunchuck_buf[2]; // * 2 * 2;
int accel_y_axis = nunchuck_buf[3]; // * 2 * 2;
int accel_z_axis = nunchuck_buf[4]; // * 2 * 2;
int z_button = 0;
int c_button = 0;
// byte nunchuck_buf[5] contains bits for z and c buttons
// it also contains the least significant bits for the accelerometer data
// so we have to check each bit of byte outbuf[5]
if ((nunchuck_buf[5] >> 0) & 1)
z_button = 1;
if ((nunchuck_buf[5] >> 1) & 1)
c_button = 1;
if ((nunchuck_buf[5] >> 2) & 1)
accel_x_axis += 2;
if ((nunchuck_buf[5] >> 3) & 1)
accel_x_axis += 1;
if ((nunchuck_buf[5] >> 4) & 1)
accel_y_axis += 2;
if ((nunchuck_buf[5] >> 5) & 1)
accel_y_axis += 1;
if ((nunchuck_buf[5] >> 6) & 1)
accel_z_axis += 2;
if ((nunchuck_buf[5] >> 7) & 1)
accel_z_axis += 1;
Serial.print(i,DEC);
Serial.print("\t");
Serial.print("joy:");
Serial.print(joy_x_axis,DEC);
Serial.print(",");
Serial.print(joy_y_axis, DEC);
Serial.print(" \t");
Serial.print("acc:");
Serial.print(accel_x_axis, DEC);
Serial.print(",");
Serial.print(accel_y_axis, DEC);
Serial.print(",");
Serial.print(accel_z_axis, DEC);
Serial.print("\t");
Serial.print("but:");
Serial.print(z_button, DEC);
Serial.print(",");
Serial.print(c_button, DEC);
Serial.print("\r\n"); // newline
i++;
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char nunchuk_decode_byte (char x)
x = (x ^ 0x17) + 0x17;
return x;
}[/u]**
[/u]** __[u]**[u]Servo Side Code[/b][/u]**[/u]__ __[u]**[u][/u]__
[u]**[u]//#include <Wire.h>
#include <Servo.h>
Servo servoLeft; // Define left servo
//Servo servoRight; // Define right servo
SoftwareSerial Wireless_Serial (2,3); //Rx | Tx
//static uint8_t nunchuck_buf[6]; // array to store nunchuck data,
servoLeft.attach(10); // Set left servo to digital pin 10
//servoRight.attach(9); // Set right servo to digital pin 9
if (Wireless_Serial.available())
Serial.write(Wireless_Serial.read());
int values = Wireless_Serial.read();
servoLeft.write(values);
}[/u][/u]
__[u]```**[/u]__
