Hi!
I'd like to add Bluetooth to my speakers.
I have an old Sony MHC-650
I also have a Raspberry Pi 4B 4Go, if that's easier to install (just heating too much - don't want some fans making noise)
I'd like to connect to my speakers even if they're on stand-by, and turning them ON just by connecting by Bluetooth, turning them OFF when disconnecting. The quality isn't a big priority, the input can be by CD (the reader is dead, so maybe if I can "emulate" it and have a digital input?), or by RCA (red and white old cables), even with a jack 3.5mm (the little one).
I need it to not overheat, no fans, a minimum quality, and not too expensive (100€ max).
Is a RasPi is more suitable? Will it be possible or not ?
But that's not what I'd like to do. I already have an amplifier, and I want to reuse it.
I want to have a little module put in the case, so it's not apparent.
Yes, but that's an old one and getting enough to buy one that actually enables and disables when connecting/disconnecting could be way too difficult.
You need to buy a Bluetooth module and have a play with it to see if can do what you want .
It looks to be as though your just want to switch it on and off ( unsure ) not stream music or choose stored music. If so that might be relatively easy .
Have a google of “ Arduino remote switch Bluetooth “
You could also do it over a Wi-Fi connection, which might be easier still.
I already have one, but I always have to turn on the speakers, turn on the bluetooth module, get my phone, and launch music. Since I turn it on/off regularly, it can be annoying sometimes. And it needs to be charged, because it's on battery, and I cannot have it always on, cause it's forcing connection when it's disconnecting.
No no, that’s the speakers that goes on stand by mode. The arduino or raspi doesn’t goes off, it keeps running to provide the Bluetooth signal and turn the speakers on.
Remote on/off switching is covered by lots of web sites and look at library examples too.
Switching on just when pairing is achieved might be a bit harder , but really only a button press away …
Hello,
Yes, I looked at your link. It's interesting, but I couldn't find a sequel to the article.
I'll describe more precisely what I'd expect :
The Arduino is always on and powered, it is broadcasting the Bluetooth.
Then, when the BLE module connects to a new device, the Arduino detects it and triggers the "Power" button, emulating a real press on the "Power" button by shorting it.
This makes the HiFi system to wake up, and receiving audio input via the RCA input from the arduino or BLE module.
Optionally, there's a cooldown for inactivity, powering off the HiFi system.
EDIT : Is it possible to send the signal to FM and plug the board in the antenna ?
