Bluetooth extender or another way to increase the range
Possible to use a ESP32 as a bluetooth extender?
I got a BBQ thermometer that is linked to my Iphone with BLE (Bluetooth Low Energy). Problem is that frequently, I lost the signal and i need to restore the link. I understand that the BLE is limited to 10 meter
Is there a way to create a Bluetooth repeater like the wifi protocole? The ESP32 receiving the device name UUID and data then retransmit those info. Iphone to detect the Thermothere Bluetooth data since the same UUID was use in the retransmit protocol
Any comment appreciated.
Excuse my English
Martin
The range of Bluetooth is not just meters. Depending on the character of obstacle between sender and receiver it varies significantly.
Likely Wifi has a better range indoors.
I'd use an ESP8266 or ESP32 to make a webserver, there are tutorials on how to do so easily.
Then I'd use a premade app made to connect to them on your WiFi.
Skip Bluetooth all together because it's range will not serve your purposes.
BLE is not limited to 10m, and should be good for a lot more than that - even if a lot less than the possible 100m. If you already have the ESP32, it is surely an as practical a way to go as any. The actual wireless in the module is common to WiFi and Bluetooth, but I understand it can be reconfigured in the loop.
With this in mind, and BLE being the obvious first choice, you may find you can stick with it, but a better BLE, whereby it connects alternately with the probe and the phone
OR, you should be able to receive the BLE from the probe and send the signal out via WiFi. All you need then is an app on the iPhone. There is probably a standard WiFi terminal that will suffice.
Thanks guy's for your input. I dud not exposed clearly my quest.
  • The BBQ thermometer is a bluetooth device by itself, not built by me . It transmit temperature of two probes to my Iphone. An app provided by the manufacturer of the thermometer will draw charts of the cooking temperature. The app tho recognised when the thermometer is on and it try to connect to is bluetooth debice name. One paired, communication is bidirectional. From my Iphone, I could set temperature target and stop the alarm buzzer.
My interogation is: is it possible to create a Bluetooth bridge or repeater using ESP32,
The controller working has a dummy tool by repeating data packet received from either Iphone or thermometer and using there respective UUID.
I understand that WiFi should be a better choice, but I need to stick with the bluetooth communication link provided by the device.
Hope it is clearer
Martin
I've been looking at making this too, and it seems that the pairing nature of BT makes it quite complex to repeat signals, meaning you pair your BBQ bluetooth to the repeater then pair your phone to the repeater.. So its obviously possible to create in IOT right?
BT>Wifi>BT seems to be the most immediate thought to do this simple and over indefinite range but the Middle transport could technically be anything or just go straight through.
Bluetooth mesh is built on BLE and seems to be more about proprietary monitoring equipment being part of a network using the Bluetooth protocols. Not that useful when wanting to watch your BBQ.
So... if we're talking about making one, we have a BBQsensor that is transmitting on BlueTooth and a service which is paired to the BBQ sender and then retransmits we can have a http hook to something else (maybe start playing "Its getting hot in here" on a speaker when bbq is ready? :D).
This becomes ;
BTBBQ>BTReceiver>ServiceSender
ServiceConsumer>Anything
This sort of implementation, if exposed to the internet, could give you a IFTTT hook, or even an Alexa hook to announce temperature. Tasker may do this.
Thats my "Get everything on a service" ten cents!
Summary
In terms of a BlueTooth repeater /extender? There are a few, but experience seems patchy. Search for "bluetooth extender" or "bluetooth passthrough" on Amazon.
For ideas on attaching BT devices via IFTTT or tasker, see the reddit groups or this link;
If this post is a bit too much, maybe move your BBQ and check where your BT signal dies. :slight_smile:
