Hi! I'm using 2 arduinos, one as a peripheral and one as a central to collect data from people in real time performing gestures. I have a tensorflow model I've made and uploaded, the recognition software is now being integrated with the bluetooth code, which is where I'm getting stuck. I'm trying to have the peripheral send the block of information to the central to be printed to the serial monitor after every "game" cycle, but I cant seem to figure out how to crack the sending part. The pairing has also been funky recently, even though I'm trying the bluetooth pairing code on its own (the bluetooth gesture example from the arduino website) and its working fine. Below is my code for the peripheral (I'm trying to get a system working for the central/peripheral deal right now, but hooking an arduino nano ble sense rev2 up to an external battery is proving to be a much harder feat than I would have imagined, so its a work in progress):
#include <ArduinoBLE.h>
#include <Arduino_BMI270_BMM150.h>
#include <TinyMLShield.h>
#include <TensorFlowLite.h>
#include <tensorflow/lite/micro/all_ops_resolver.h>
#include <tensorflow/lite/micro/micro_error_reporter.h>
#include <tensorflow/lite/micro/micro_interpreter.h>
#include <tensorflow/lite/schema/schema_generated.h>
#include <tensorflow/lite/version.h>
#include "model.h"
const float accelerationThreshold = 2.5; // Threshold of significant acceleration in G'
const float gyroscopeThreshold = 500.0;
const int numSamples = 119;
const int maxRounds = 20;
const int maxGestureCount = 12;
const int vibrationPin = 9;
const int ledPin = 13;
const char* deviceServiceUuid = "19b10000-e8f2-537e-4f6c-d104768a1214";
const char* deviceServiceCharacteristicUuid = "19b10001-e8f2-537e-4f6c-d104768a1214";
BLEService gestureService(deviceServiceUuid);
BLEByteCharacteristic gestureCharacteristic(deviceServiceCharacteristicUuid, BLERead | BLEWrite);
int samplesRead = numSamples;
int currentRound = 1;
int punchCount = 0;
int flexCount = 0;
unsigned long roundStartTime = 0;
unsigned long lastVibrationTime = 0;
struct GestureData {
const char* gestureName;
unsigned long gestureTime;
GestureData gestureData[maxRounds];
int currentRoundIndex = 0;
// Global variables used for TensorFlow Lite (Micro)
tflite::MicroErrorReporter tflErrorReporter;
tflite::AllOpsResolver tflOpsResolver;
const tflite::Model* tflModel = nullptr;
tflite::MicroInterpreter* tflInterpreter = nullptr;
TfLiteTensor* tflInputTensor = nullptr;
TfLiteTensor* tflOutputTensor = nullptr;
// Create a static memory buffer for TFLM. The size may need to
// be adjusted based on the model you are using.
constexpr int tensorArenaSize = 8 * 1024;
byte tensorArena[tensorArenaSize] __attribute__((aligned(16)));
// Array to map gesture index to a name
const char* GESTURES[] = {
"punch",
"flex"
#define NUM_GESTURES (sizeof(GESTURES) / sizeof(GESTURES[0]))
while (!Serial);
if (!BLE.begin()) {
Serial.println("- Starting Bluetooth® Low Energy module failed!");
while (1);
BLE.setLocalName("Arduino Nano 33 BLE (Peripheral)");
BLE.setAdvertisedService(gestureService);
gestureService.addCharacteristic(gestureCharacteristic);
BLE.addService(gestureService);
gestureCharacteristic.writeValue(-1);
BLE.advertise();
if (!IMU.begin()) {
Serial.println("- Failed to initialize IMU!");
while (1);
Serial.println("Nano 33 BLE (Peripheral Device)");
Serial.println(" ");
pinMode(vibrationPin, OUTPUT);
pinMode(ledPin, OUTPUT);
// Initialize the IMU
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1);
// Print out the sample rates of the IMUs
Serial.print("Accelerometer sample rate = ");
Serial.print(IMU.accelerationSampleRate());
Serial.println(" Hz");
Serial.print("Gyroscope sample rate = ");
Serial.print(IMU.gyroscopeSampleRate());
// Get the TFL representation of the model byte array
tflModel = tflite::GetModel(model);
if (tflModel->version() != TFLITE_SCHEMA_VERSION) {
Serial.println("Model schema mismatch!");
while (1);
// Create an interpreter to run the model
tflInterpreter = new tflite::MicroInterpreter(tflModel, tflOpsResolver, tensorArena, tensorArenaSize, &tflErrorReporter);
// Allocate memory for the model's input and output tensors
tflInterpreter->AllocateTensors();
// Get pointers for the model's input and output tensors
tflInputTensor = tflInterpreter->input(0);
tflOutputTensor = tflInterpreter->output(0);
startNewRound();
void startNewRound() {
digitalWrite(ledPin, LOW);
// Randomly select the gesture
int gestureIndex = random(NUM_GESTURES);
if (gestureIndex == 0) {
punchCount++;
flexCount++;
gestureData[currentRoundIndex].gestureName = GESTURES[gestureIndex];
gestureData[currentRoundIndex].gestureTime = 0;
// Check if the gesture count exceeds the maximum
if (punchCount > maxGestureCount || flexCount > maxGestureCount) {
endGame();
return;
// Print the current gesture
Serial.print("Current Gesture: ");
Serial.println(GESTURES[gestureIndex]);
// Start the timer
roundStartTime = millis();
Serial.println("Timer Start");
void endGame() {
digitalWrite(ledPin, HIGH);
Serial.println("Game Over");
String bulkData;
for (int i = 0; i < currentRoundIndex; i++) {
bulkData += "Round ";
bulkData += i + 1;
bulkData += ": Gesture: ";
bulkData += gestureData[i].gestureName;
bulkData += ", Time Taken: ";
bulkData += gestureData[i].gestureTime / 1000;
bulkData += " sec\n";
// Set the value of the characteristic
const char* bulkDataStr = bulkData.c_str();
gestureCharacteristic.write(bulkDataStr);
// Print the bulk data to the serial monitor
Serial.print(bulkData);
float aX, aY, aZ, gX, gY, gZ;
while (samplesRead == numSamples) {
if (IMU.accelerationAvailable()) {
// Read the acceleration data
IMU.readAcceleration(aX, aY, aZ);
// Sum up the absolute values
float aSum = fabs(aX) + fabs(aY) + fabs(aZ);
// Check if it's above the threshold
if (aSum >= accelerationThreshold) {
// Reset the sample read count
samplesRead = 0;
while (samplesRead < numSamples) {
// Check if new acceleration AND gyroscope data is available
if (IMU.accelerationAvailable() && IMU.gyroscopeAvailable()) {
// Read the acceleration and gyroscope data
IMU.readGyroscope(gX, gY, gZ);
// Normalize the IMU data between 0 and 1 and store it in the model's input tensor
tflInputTensor->data.f[samplesRead * 6 + 0] = (aX + 4.0) / 8.0;
tflInputTensor->data.f[samplesRead * 6 + 1] = (aY + 4.0) / 8.0;
tflInputTensor->data.f[samplesRead * 6 + 2] = (aZ + 4.0) / 8.0;
tflInputTensor->data.f[samplesRead * 6 + 3] = (gX + 2000.0) / 4000.0;
tflInputTensor->data.f[samplesRead * 6 + 4] = (gY + 2000.0) / 4000.0;
tflInputTensor->data.f[samplesRead * 6 + 5] = (gZ + 2000.0) / 4000.0;
samplesRead++;
if (samplesRead == numSamples) {
// Run inference
TfLiteStatus invokeStatus = tflInterpreter->Invoke();
if (invokeStatus != kTfLiteOk) {
Serial.println("Invoke failed!");
while (1);
return;
// Find the recognized gesture
int recognizedGestureIndex = 0;
float maxConfidence = tflOutputTensor->data.f[0];
for (int i = 1; i < NUM_GESTURES; i++) {
if (tflOutputTensor->data.f[i] > maxConfidence) {
recognizedGestureIndex = i;
maxConfidence = tflOutputTensor->data.f[i];
// Check if the recognized gesture matches the current gesture
if (recognizedGestureIndex == 0 && GESTURES[recognizedGestureIndex] == GESTURES[punchCount - 1]) {
unsigned long gestureTime = millis() - roundStartTime;
Serial.print("Correct Gesture: ");
Serial.print(GESTURES[recognizedGestureIndex]);
Serial.print(", Time Taken: ");
Serial.print(gestureTime / 1000);
Serial.println(" sec");
gestureData[currentRoundIndex].gestureTime = gestureTime;
delay(200);
startNewRound();
currentRoundIndex++;
} else if (recognizedGestureIndex == 0 && GESTURES[recognizedGestureIndex] == GESTURES[flexCount - 1]) {
delay(200);
startNewRound();
if anyone has any changes they can think for me to make, I'd really apprecite the help! The void endgame part is the one that keeps getting caught in the compiler, but if any other areas need changing just let me know!
