hey i am transferring data using Bluetooth module HC-05.. my data is long almost containing 150 to 200 values like ( 1200 usec , 500 uses) this is in one line and i have to send 200 lines together... when i am using HC-05 i lost my data almost 40 percent and the next time i send i only receive first digit of first line only... i switch to HC-06 and again send data but this time i receive data every time i send but i almost receive 55 percent of data remaining data is lost and some raw values are also received ... any body please help...
Don't expect any help until you are a little less secretive about your code. You might also be forthcoming about your intent with the data. You should not expect any difference in performance between HC-05 and HC-06.
HC05 and HC06 modules behave a little differently from each other. Without knowing what the code is doing it is impossible to answer your question.
