Bluetooth HC-05 module won't talk to Arduino in terminal mode
I have a DSD Tech HC-05 bluetooth module connected to an Arduino Mega 2560. It is able to connect to a remote master and transmit and receive data to the Arduino, verified using the BluTerm app on an iMac and using a simple pass-through program on the Arduino to pass serial data between the HC-05 serial port and the Arduino IDE serial port, both at 9600 bps. When I power up the HC-05 while holding the button, it enters terminal mode as evidenced by the LED blinking very slowly. However, the Arduino never sees any output from the HC-05 in this mode, e.g. no response to "AT" or "AT+VERS?". I first tried using 38400 bps for the HC-05 connection, then when that didn't work I tried 9600, 115200, 19200, 1200, and 2400. None work.
Here is how the HC-05 is connected:
Wall Wart ground to HC-05 GND
Wall Wart +5V to HC-05 VCC
Arduino Mega pin 17 (RX2) to HC-05 TXD
Arduino Mega pin 18 (TXD) to 1K resistor, other side of it connects to HC-05 RXD and to a 2K resistor that connects to ground.
Here is the code, at 38400 for the HC-05:
  Serial2.begin(38400); // Required bps for AT mode?
  if (Serial2.available()) Serial.write(Serial2.read());
  if (Serial.available()) Serial2.write(Serial.read());
Some posts suggest setting pin 17 (RX2) to input with pull-up, but that makes no difference, and besides, it can receive from the HC-05 just fine in regular mode.
Any suggestions?
Addendum with answer:
I was working with the wrong data sheet, the HC-10 rather than HC-05. Reading the correct one, I saw something and tried it out and sure enough, that was the problem. What was it? Every command must end in '\r\n' (carriage return followed by line feed). But the Arduino was sending only a line feed '\n' at the end of each line. Adding '\r' before it was all it took to make it work! Here is the new code:
  Serial2.begin(38400); // Required for AT mode
  if (Serial.available()) {
    char ch = Serial.read();
    if (ch == '\n') Serial2.write('\r');
    Serial2.write(ch);
A sad discovery
After getting the HC-05 working, I discovered I can't connect to the iPhone, the HC-05 doesn't work with IOS, apparently due to some sort of legal issue. I'm going to switch to an HM-10.
No it isn't, the slow flash tells you that it is in AT mode ( as a result of you pushing the button ) and therefore cannot communicate by wireless with anything. Solution: don't push the button.
The code I was reading used the term "terminal mode" for "AT" mode. Is that wrong usage? At any rate, yes, I understand that pressing the button activates AT mode, and that is exactly what I wanted to test. Found the problem though, see modified question above.
I would say yes... In AT mode, called by normal people AT mode, one may use a terminal to communicate by wire for configuration purposes. In communications mode, one may use a terminal to communicate wirelessly via Bluetooth.
Thanks. Using the correct terminology is important!
