Ok so, I'm trying to receive some data from arduino uno using HC-05 module on the IDE on my computer, Until now I was beeing able to connect it with the PC, when I open the IDE with the COM6 port I received the information but in weird characters, so I thought that maybe a problem with the velocity of the HC-05 is configured, so I changed it to 38400,0,0... It didn't work so I used the AT command AT+ORGL to return it to factory patterns.
Anyway, I've done this and now my PC won't give the bluetooth a Serial Port to communicate, the velocity is 38400,0,0 and the code I'm using is:
#include<SoftwareSerial.h>
SoftwareSerial BT(10,11);
pinMode(9,OUTPUT);
digitalWrite(9,HIGH);
BT.begin(38400);
Serial.println("Bluetooth AT command mode");
if(BT.available())
Serial.write(BT.read());
if(Serial.available())
BT.write(Serial.read());
Serial.write("banana");
