Bluetooth HC-06 AT responds only to ONE command
Hello, recently I bought HC-06 adapter. I want to change it's baud rate. I searched almost entire web and nothing works. The only command I can work with is AT+NAMExxx. Then I get answer OKsetname, as expected. AT, AT+VERSION, AT+BAUDx, AT+PINxxxx, nothing returns any message. I'm using this sketch. I'm using SoftwareSerial, voltage divider. Also bought today second module, nothing changed.
// Basic Bluetooth sketch HC‐06_01
// Connect the Hc‐06 module and communicate using the serial monitor
// The HC‐06 defaults to AT mode when first powered on.
// The default baud rate is 9600
// The Hc‐06 requires all AT commands to be in uppercase. NL+CR should not be added to the command string
#include <SoftwareSerial.h>
SoftwareSerial BTserial(2, 4); // RX | TX
// Connect the HC‐06 TX to the Arduino RX on pin 2.
// Connect the HC‐06 RX to the Arduino TX on pin 3 through a voltage divider.
Serial.println("Enter AT commands:");
// HC‐06 default serial speed is 9600
BTserial.begin(9600);
// Keep reading from HC‐06 and send to Arduino Serial Monitor
if (BTserial.available())
Serial.write(BTserial.read());
// Keep reading from Arduino Serial Monitor and send to HC‐06
if (Serial.available())
BTserial.write(Serial.read());
This makes no sense. If one command works, they all should. I'm guessing that it is a timing problem. The code below might fix that. It uses your wiring and is one shot - no hands.
 One Shot
 Kudos to marguskohv - he sowed the seed....
Serial monitor is just aide memoire
SoftwareSerial Serial1(2, 4); // RX | TX
String command = ""; // Stores response from HC-06
  Serial.begin(9600);       //monitor
  Serial1.begin(9600);      //bluetooth
  Serial.print("AT      ");
  Serial1.print("AT");                  //PING
  if (Serial1.available()) {
    while(Serial1.available()) { // While there is more to be read, keep reading.
    delay(3);
    char c = Serial1.read();
      command += c;
  delay(2000);
  Serial.println(command);
  command = ""; // No repeats
  Serial.print("AT+NAMEFosters      ");
  Serial1.print("AT+NAMEFosters");        //CHANGE NAME
        delay(3);
      command += (char)Serial1.read();
  delay(2000);
  Serial.println("AT+PIN1234");
  Serial1.print("AT+PIN1234");        //CHANGE PASSWORD
        delay(3);
  delay(2000);
  Serial.print("AT+BAUD8      ");
  Serial1.print("AT+BAUD8");               //CHANGE SPEED TO 115K
delay(2000);
void loop(){
}   //one-shot - nothing here
My instinct is that it's a software serial problem, ie, you're trying to send and receive from a software serial at the same time. SoftwareSerial is only half-duplex - it can only send OR receive at a given moment.
Thanks guys, code privided by Nick works great. Don't know what was going on with this one command, but for now it is perfect, thanks
Glad to hear that my code helped, I have never used it myself as I never use software serial. I suspect DrAzzy's post explained your problem better than my guess.
