Bluetooth HC-06 module does not appear to pair
Hello, guys
I am trying to learn how to integrate Bluetooth and Arduino. So I developed a small electrical circuit and my HC-06 module keeps blinking when I turn on my Board. But when I search for the HC-06 module to pair with, I can't find it... I have tried to search on my laptop, on my phone (iOS and Android), no luck!
Do you guys happen to know if there is some sort of a trick? because I've tried everything and the HC-06 just won't show up
Thank you in advance
The probable reason for the deafening silence is that yu have not posted this on the networking forum. Your problem is probably at the phone end. A fast flash - about 2Hz indicates power on and ready to connect, and power is all you actually need in order to pair. There is no "trick", but forget the iPhone. It is incompatible.
You might find the following background notes useful.
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
