Hello everyone, I noticed that arduino with bluetooth passes data but the phone receives them badly. Does anyone know how to encode the arduino character (module HC-06) when transmitting data?
Text does NOT need encoding. The problem is on the phone.
I think that's dumb, and you should look at Arduino, not the phone. I'm sure it will be easier, and more likely to get a result. Indeed, don't even ask what to do to fix the phone. Your code is conspicuous by its absence, but a fair guess is that it actually might not be about the code anyway, it is simply that HC-06 is configured to work at one baud rate while Arduino is talking at another. If you are getting odd symbols etc., and you have not reconfigured HC-06, you might find that changing the code to
Serial.begin(9600):
might fix it.
A code problem may be that you are sending so much data so fast that it is tripping over itself and garbling the output
The only "encoding" you need to know is
Serial.print(stuff);
