I am looking for a solution to activate some LED's by bluetooth.
I simply need to transmit 3 different commands generated from 3 different +12volt power lines that are activated by a switch.
On the Receiver side I want to activate a number of LED's per command.
The solution should be able to handle two commands simultaneously.
Ideally I would like to add a 4th input in order to have one set of LED's start blinking once two certain inputs are combined.
Looking forward to learn what modules I would need to make this happen.
Smiles across the wires,
Rogier
