BlueTooth issue
I have created a small Arduino sensor system which is supposed to send data to the ardutooth app. The device connects and values show up in the serial monitor, but in the app, nothing seems to work. Can anyone tell what's wrong by looking at this code?
//Code made quickly by Maciej Wojciechowski, expect nonoptimal performance. Feel free to edit and improve.
#include <SoftwareSerial.h>
#include "DHT.h"
#define DHTPIN 5
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
int trigPin = 11;
int echoPin = 12;
long duration, cm, inches;
SoftwareSerial BTserial(7, 8); //RX and TX pin
BTserial.begin(9600); //Initializes BT module
Serial.begin(4800); //Initializes Serial monitor, for debug
dht.begin(); //Starts up DHT-11 module
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT); //Sets which pin to use for input and output
//LED to make sure everything works
pinMode(LED_BUILTIN, OUTPUT);
delay(2000); //small pause for DHT-11
float t = dht.readTemperature(); //Sets t variable to temperature
float h = dht.readHumidity(); //Sets h variable to humidity
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10); //pulses the trigger pin, ensures a clean pulse
duration = pulseIn(echoPin, HIGH); //Sets the value of duration to duration between input and output
cm = (duration/2) / 29.1;
inches = (duration/2) / 74;
//Divide by 2 then by a set value found online.
//now we tell the arduino to print values via BT
BTserial.print(t);
BTserial.print(",");
BTserial.print(h);
BTserial.print(cm);
BTserial.print(inches);
BTserial.print(";");
Serial.print("\r\n");
Serial.print(t);
Serial.print("*C");
Serial.print(h);
Serial.print("%");
Serial.print(cm);
Serial.print("cm");
Serial.print(inches);
Serial.print("inches");
Serial.print("----------------------");
delay(20);
//LED light
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
This is the app: https://play.google.com/store/apps/details?id=com.frederikhauke.ArduTooth
Thanks in advance.
It could be the wiring - Rx>Tx and Tx>Rx. The values seem nonsensical and best left out of the game for the moment. Just say "hello". Use a standard terminal like BlueTerm to prove the communications.
I tried that and it didn't work. Nothing would print; I then decided to use different pins instead of RX and TX. I'll try out a different app, thanks for the suggestion!
You might find the following background notes useful.
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
IF you are getting what you want on the serial monitor, AND Bluetooth baud rate is same as serial monitor, all you need do is connect Bluetooth to pins 0,1.
Do I have to use the RX and TX pins? I thought that softwareserial allows me to use any digital pin.
Read the notes. Software serial indeed allows you to use other pins, you have not said why you would want to do that. I have said that all you need do is put Bluetooth on pins 0,1. I did not say that is what you must do.
Oh, thank you. Forgive me, I'm horribly tired today.
I'll try this method when I get back home today. Thanks for everything!
