Right, my first exhibit!
It's an idea for an electronic wind instrument that I have been working on. It uses a SoftPot (sliding pitch control) and an MPX5010DP differential pressure sensor (breath control).
I call it the taquito and it lives here.
Recently I got an LM400 Bluetooth module that I've been keen to try out, so I decided to connect it to the taquito. The strip board has a connection for a ttl-to-usb cable. I used this to plug into a breadboard with the bluetooth module and a voltage regulator on it.
Some photos are here (flickr).
To explain why there's an arduino in some photos and an onboard AtMega8 in others, this is why:
I built the project on stripboard as an arduino shield, this is what you can see being played in the silly little video I did.
Then I modified it by adding the processor, caps etc. and a connector for the FT232RL cable.
Therefore, with the bluetooth addition and a battery, the device is completely standalone.
If there's interest/curiosity I'll transfer the schematic from fag packet to eagle and put it up on the site - it's pretty simple though as you can probably tell from the photos.
enjoy!
/m
