Bluetooth module HC-06 seems dead
Bluetooth module HC-06 seems dead, I dont know how to see if its working or not because the Led does not flash. At first I had some time to connect to do the phone and then it automatically disconnected and stoped blinking. Needing some real help because of this project! Thank you
miguelportugal:
You have two possibilities:
  1. It looks dead because it is dead
  2. It looks dead but it isn't. A ground or power wire is disconnected
What ground or power? There goes an image
This might be a surprise for you but, if you want a LED to flash, you need to connect it to some source of electricity. I expect you have already done that before, but maybe not have recognised the significance of what you did. Ensure that the VCC pin on HC-06 is connected to 5v and GND is connected to ground. This particularly applies if you are using a cheapo breadboard. If you are powering HC-06 from Arduino, now might be a good time to check the LED on that is working. If it isn't, don't expect too much from the HC-06.
