bluetooth module issue with UNO
Hi, my bluetooth module runs fine with duemilanove, but with the same wiring and sketch, it somehow didn't run properly on UNO. I can send text to the bluetooth, but it doesn't seem to response my input command. My sketch is simply a led switch.
char val;         // variable to receive data from the serial port
int ledpin = 4;  // LED connected to pin 2 (on-board LED)
  pinMode(ledpin, OUTPUT);  // pin 13 (on-board LED) as OUTPUT
  Serial.begin(9600);       // start serial communication at 115200bps
  Serial.println("Enter");
  if( Serial.available() )       // if data is available to read
    val = Serial.read();         // read it and store it in 'val'
  if( val == '0' )               // if '0' was received led 13 is switched off
   digitalWrite(ledpin, LOW);    // turn Off pin 13 off
delay(1000);                  // waits for a second
Serial.println("Pin 4 : off");
if( val == '1' )               // if '1' was received led 13 on
    digitalWrite(ledpin, HIGH);  // turn ON pin 13 on
    Serial.println("Pin 4 : on");
If there is serial data to read, do nothing. If not, do nothing. Why bother?
By the way, Serial.available() returns the number of bytes available to read, not true or false. Don't code it like it returns true or false if you want your code to really be readable.
Then, regardless of whether there is data to read, or not, read some. Wrong!
