Guys, I need the bthc05 library. I couldn't find it anywhere. Can someone send me the link?
If it is the HC-05 Bluetooth module you are looking for then you don't need a library as it is simply a serial device that you can write to and read from
Arduino: 1.8.13 (Windows 10), Плата:"Arduino Uno"
LaserCat:4:10: fatal error: BTHC05.h: No such file or directory
#include "BTHC05.h"
compilation terminated.
exit status 1
Showing this
Where did you get the code that you didn't post ? (BIG HINT)
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
Perhaps try a Google search on BTHC05.h ?
How hard did you look for the library ?
I am trying to make this project. But the code is giving an error.
Which project ?
// Include Libraries
#include "VarSpeedServo.h"
#include "Arduino.h"
#include "BTHC05.h"
// Pin Definitions
#define BTHC05_PIN_RXD 10
#define BTHC05_PIN_TXD 11
#define LASER_PIN_S 2
#define SERVO9G1_PIN_SIG 3
#define SERVO9G2_PIN_SIG 4
// Global variables and defines
// object initialization
VarSpeedServo servo9g1;
VarSpeedServo servo9g2;
BTHC05 bthc05(BTHC05_PIN_RXD, BTHC05_PIN_TXD);
bool laserState = 0;
bool autoplayState = 0;
const int servoSpeed = 10;
const int seqIntervalDelta = 50;
const int manualyServoMinStep = 5;
const int manualyServoMaxStep = 20;
const int minimalRangeSize = 10;
// Change these parameters to define the rectangular play area
int servo1Min = 80;
int servo1Max = 110;
int servo2Min = 20;
int servo2Max = 50;
int servo1pos = (servo1Min + servo1Max) / 2;
int servo2pos = (servo2Min + servo2Max) / 2;
int delayVal = 300;
// Setup the essentials for your circuit to work. It runs first every time your circuit is powered with electricity.
// Setup Serial which is useful for debugging
// Use the Serial Monitor to view printed messages
while (!Serial) ; // wait for serial port to connect. Needed for native USB
Serial.println("start");
bthc05.begin(9600);
//This example uses HC-05 Bluetooth to communicate with an Android device.
//Download bluetooth terminal from google play store, https://play.google.com/store/apps/details?id=Qwerty.BluetoothTerminal&hl=en
//Pair and connect to 'HC-05', the default password for connection is '1234'.
//You should see this message from your arduino on your android device
bthc05.println("Bluetooth On....");
servo9g1.attach(SERVO9G1_PIN_SIG); // 1. attach the servo to correct pin to control it.
servo9g2.attach(SERVO9G2_PIN_SIG); // 1. attach the servo to correct pin to control it.
pinMode(LASER_PIN_S, OUTPUT);
// start with laser off
digitalWrite(LASER_PIN_S, laserState);
servo9g2.write(servo2pos , servoSpeed);
servo9g1.write(servo1pos , servoSpeed);
// Main logic of your circuit. It defines the interaction between the components you selected. After setup, it runs over and over again, in an eternal loop.
String bthc05Str = "";
//Receive String from bluetooth device
if (bthc05.available())
//Read a complete line from bluetooth terminal
bthc05Str = bthc05.readStringUntil('\n');
// Print raw data to serial monitor
// Serial.print("BT Raw Data: ");
// Serial.println(bthc05Str);
// Settings
// Turn laser On/Off
if (bthc05Str == "Laser On/Off") {
laserState = !laserState;
Serial.print("Laser: ");
Serial.println(laserState);
// decrease the delay between random points in Autoplay mode
else if (bthc05Str == "Speed Up") {
delayVal -= seqIntervalDelta;
Serial.print("delay: ");
Serial.println(delayVal);
// increase the delay between random points in Autoplay mode
else if (bthc05Str == "Speed Down") {
delayVal += seqIntervalDelta;
// Enable Autoplay - random points
else if (bthc05Str == "Autoplay") {
autoplayState = !autoplayState;
Serial.print("AutoPlay: ");
Serial.println(autoplayState);
// Widen the servo margins
else if (bthc05Str == "Area +") {
servo1Min -= 5;
servo1Max += 5;
servo2Min -= 5;
servo2Max += 5;
servo1Min = constrain(servo1Min, 0, servo1Max);
servo1Max = constrain(servo1Max, servo1Min, 180);
servo2Min = constrain(servo2Min, 0, servo2Max);
servo2Max = constrain(servo2Max, servo2Min, 180);
Serial.print("Area +: ");
char buf[20];
sprintf(buf, "%d,%d,%d,%d", servo1Min, servo1Max, servo2Min, servo2Max);
Serial.println(buf);
// tighten the servo margins
else if (bthc05Str == "Area -") {
if (servo1Max - servo1Min > minimalRangeSize) {
servo1Min += 5;
servo1Max -= 5;
if (servo2Max - servo2Min > minimalRangeSize) {
servo2Min += 5;
servo2Max -= 5;
Serial.print("Area -: ");
char buf[20];
// Functionality
if (autoplayState || bthc05Str == "Random Position") {
servo9g2.write(random(servo2Min, servo2Max), servoSpeed);
servo9g1.write(random(servo1Min, servo1Max), servoSpeed);
// waits until servos reaches destination
servo9g2.wait();
servo9g1.wait();
delay(random(delayVal, delayVal * 5));
else {
// Move the laser manually in random size steps from 5 - 20 deg
if (bthc05Str == "Up") {
servo2pos += random(manualyServoMinStep, manualyServoMaxStep);
servo2pos = constrain(servo2pos, servo2Min, servo2Max);
servo9g2.write(servo2pos, servoSpeed);
// waits until servo reaches destination
servo9g2.wait();
Serial.println(servo2pos);
else if (bthc05Str == "Down") {
servo2pos -= random(manualyServoMinStep, manualyServoMaxStep);
servo9g2.wait();
else if (bthc05Str == "Left") {
servo1pos += random(manualyServoMinStep, manualyServoMaxStep);
servo1pos = constrain(servo1pos, servo1Min, servo1Max);
servo9g1.write(servo1pos, servoSpeed);
servo9g1.wait();
else if (bthc05Str == "Right") {
servo1pos -= random(manualyServoMinStep, manualyServoMaxStep);
servo9g1.wait();
So, do you have the BTHC05 library installed and if so where is it located ?
NO it isn't, I couldn't find that lib
See the link in my reply #6
How do I install? Tell me please.
Create a folder named BTHC05 in the libraries folder of your sketchbook folder and put BTHC05.h and BTHC05.cpp in the folder and it will be available to all sketches
Alternatively put the 2 library files in the same folder as your sketch and the library will be available to that sketch
worked
Thanks a lot!
