Bluetooth Module not connecting to App but connected to phone - help!
Wawa:
First thing I noticed it that the tap (center) of the voltage divider isn't connected to anything.
So you made a mess of it again (after you had it right).
I wonder if you have understood how a breadboard works.
Can't see how you have connected the rest of the BT wiring from this image.
Why did you move the BT module off the breadboard.
Leo..
  1. the center is connected to the ground pin on the bt module
  2. i had to move things around b/c everything was getting squished together
  3. i had to move the bt module off the breadboard b/c it won't work on the breadboard for some reason
