Bluetooth module only outputting 255
Playing around with the HC-05 bluetooth module and can't seem to get it working. I'm using the simple sketch from the arduino website Link.
int state = 0;
  Serial.begin(9600); // Default communication rate of the Bluetooth module
  if(Serial.available() > 0){ // Checks whether data is comming from the serial port
    state = Serial.read(); // Reads the data from the serial port
    Serial.print(state);
Connections: Arduino HC-05
TX > RX RX > TX 5V > 5V GND > GND
I use one of the apps on the playstore to connect to the module and send data. The only thing I receive is 255 (or 11111111 or ?). Sometimes I receive different data but it is very inconsistent. It is really starting to annoy me so I would like some help. Thanks in advance.
If code is from Arduino website, it should be kosher, but it [u]might[/u] be a little unstable without a little delay. Try
String readString;
char c;
    pinMode(0, INPUT_PULLUP);// only needed for  JY-MCU v1.06?
    Serial.println("OK then, you first, say something.....");
    Serial.println("Go on, type something and hit Send,");
    Serial.println("or just hit the Enter key,");
    Serial.println("then I will repeat it!");
    Serial.println("");
    while (Serial.available())
    delay(3);
    c = Serial.read();
    readString += c;
  }// end while
  if (readString.length() >0)
    Serial.write(c);
   readString="";
  } // end if
