bluetooth module sending false data [SOLVED]
Hello everyone.
My project needs to send data between Master-Slave using Bluetooth modules hc05, hc06, I configured the hc05 to be Master and did the following:
  1. changed the baud to 9600 for hc05 ( hc06 is d 9600 by default )
  2. set hc05 as master
  3. automatically connect hc05 to hc06 Bluetooth module using hc06 address
everything is fine but some of the data that I sent from master to slave are false and some of them are correct!!
ex: sending (L) from the master the slave received (A);
I tried to add a delay between each character I send but nothing changed!
bluetooth modules - Arduino Uno
Tx - Rx pin(0)
Rx - Tx pin(1)
gnd - gnd
vcc - 3v
any help will be appreciated.
Serial.write('L');
  delay(600);
  Serial.write('L');
  delay(600);
  Serial.write('E');
SOLVED since I am newbie to the Arduino and after searching for Serial Communication it listed that even if the Arduino has multiple Serial Communication ports only one port will be used and because I am powering the Arduino through its USB port some collisions happened ( 0,1 to Bluetooth module and USB to the power )
using SoftWareSerial solved the problem.
thank you all
That is not complete code. Please post your complete code (or a stripped down version that displays the problem) so others can replicate/debug it an help you. Snippets of code are not useful.
The baud rate is the rate at which you communicate with the module, it has nothing to do with how they communicate with each other.
blh64:
the below code is from the master arduino
delay(3000);
  Serial.write('L');
  Serial.write('L');
  Serial.write('E');
and the below code is from slave Arduino
the below code is from the master Arduino
  if(Serial.available()>0)
  Serial.println((char) Serial.read());
So, why doesn't that code ever call Serial.begin()?
Same question.
my fault because i deleted Serial.begin(9600) with the comments that i was using,i mean it was in the code before the upload here !
