Bluetooth module serial problems
Hi all,
I bought a simple serial bluetooth module for my arduino mega, and I am sending it information from a processing sketch on my PC. I am able to get an LED to blink using this code.
char val;
int pin = 13;
   pinMode(pin, OUTPUT);
   while(Serial.available()){
    char inChar = (char)Serial.read();
    switch(inChar){
       case '1': digitalWrite(pin, HIGH);
       case '0': digitalWrite(pin, LOW);
    Serial.println(inChar);
however, when I switch the pins to Serial1 and use this code the LED doesn'd blink
char val;
int pin = 13;
   Serial1.begin(9600);
   while(Serial1.available()){
    char inChar = (char)Serial1.read();
    switch(inChar){
My processing sketch just alternates between sending a 1 and 0 to the module as chars
import processing.serial.*;
Serial myPort;
//String val;
//int high = 1;
//int low = 0;
void setup(){
  printArray(Serial.list());  //list of serial ports
  myPort = new Serial(this, Serial.list()[1], 9600); //the port with the module
void draw(){
     myPort.write('1');
     myPort.write('0');
