Hi All,
I am currently working on a sensor device, using an Uno R4 WIFI, where the readings from 2 Sharp IR Sensors are read, and then displayed on both an OLED Display, which is updated every 2 seconds, as well as a tablet via Bluetooth, updated every Minute. Unfortunately it is not working, the OLED display remains blank, and the Bluetooth doesn't seem to update/display the assigned values. I based the code on the included "Battery Monitor" example, which I modified. For reference, I am using the Nordic nRF Connect & nRF Logger apps, on the tablet. apologizes if the code is a bit messy.
My Questions are:
- Why is the OLED Display, not displaying/updating the output?
2)Why does the tablet not update/display the assigned values?
- 2a) Do I need to remedy this on the tablet, if so how?
Code is modified from Battery Monitor Example found in BLE library
//Libraries used by Board.
#include <SharpIR.h>
#include <ArduinoBLE.h>
//included libraries OLED Display
#include "SPI.h" //Includes library for SPI communication of display
#include "Adafruit_GFX.h" //Includes core graphics library
#include "Adafruit_SSD1351.h" //Includes hardware specific library
//OLED screen dimensions
#define SCREEN_WIDTH 128 //pixel width
#define SCREEN_HEIGHT 128 //pixel height
//OLED pin definitions
#define SCLK_PIN 13 //defines s clock pin
#define MOSI_PIN 11 //defines master-out slave-in SDA pin
#define RST_PIN 3 //defines reset pin
#define DC_PIN 5 //defines master-in slave-out pin
#define CS_PIN 4 //defines chip select pin
// Colour definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define GREY 0x8410
#define ORANGE 0xE880
//OLED Display Parameter definitions
Adafruit_SSD1351 display = Adafruit_SSD1351(SCREEN_WIDTH, SCREEN_HEIGHT, &SPI, CS_PIN, DC_PIN, RST_PIN);
//Sharp IR Sensors with pinout Addresses
SharpIR sensorLeft( SharpIR::GP2Y0A02YK0F, A0 );
SharpIR sensorRight( SharpIR::GP2Y0A02YK0F, A1 );
// Bluetooth® Low Energy Battery Service
BLEService cc5IRSensorService("21027c5d-e0af-4097-bb81-38c2d9abce12");
// Bluetooth® Low Energy Battery Level Characteristic - MODIFY TO IR SENSORS
BLEUnsignedCharCharacteristic southIRSensorChar("47054fb1-cd0e-46df-9695-c9f804be82a4", // standard 16-bit characteristic UUID
BLERead | BLENotify | BLEBroadcast | BLEWrite); // remote clients will be able to get notifications if this characteristic changes
BLEUnsignedCharCharacteristic northIRSensorChar("a7264e56-29f0-4972-9f0f-24f1bc218ee5", // standard 16-bit characteristic UUID
//Set Global Variables
int Avgleftdeflect = 0; //Avg of 20 IRSensor readings across 200 millis
int Avgrightdeflect = 0;
int southEdge = 0; // last deflection reading from South IR Sensor.
int northEdge = 0; // last deflection reading from North IR Sensor.
unsigned long previousMillis = 0; // last time the deflection was checked, in ms.
unsigned long blueLEDelay = 60000; //delay between updates to bluetooth.
unsigned long displayPrevious = 0; //time since last output to OLED Display.
unsigned long oledDelay = 2000; //OLED Display update delay
//String outputs for OLED Display
String Ldis;
String rightDistance;
display.begin(); //OLED Display Set Up
display.fillScreen(BLACK);
display.setRotation(2);
Serial.begin(9600); // initialize serial communication
while (!Serial);
pinMode(LED_BUILTIN, OUTPUT); // initialize the built-in LED pin to indicate when a central is connected
// begin initialization
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
/* Set a local name for the Bluetooth® Low Energy device - MODIFY TO SEND/RECIEVE IR SENSOR DATA
Create and Assign advertised Service
Assign sensor characteristics to service
BLE.setLocalName("CC5 Slack Edge Sensor");
BLE.setAdvertisedService(cc5IRSensorService); // add the service UUID
cc5IRSensorService.addCharacteristic(southIRSensorChar); // add the South IR Sensor characteristic
cc5IRSensorService.addCharacteristic(northIRSensorChar); // add the North IR Sensor characteristic
BLE.addService(cc5IRSensorService); // Add the IR Sensor service
southIRSensorChar.writeValue(southEdge); // set initial value for southIRSensor characteristic
northIRSensorChar.writeValue(northEdge); // set initial value for northIRSensor characteristic
// start advertising
BLE.advertise();
Serial.println("Bluetooth® device active, waiting for connections...");
int dValsouth;
int dValnorth;
for (int i = 0; i <= 20; i++) {
int lftdft = 30 - sensorLeft.getDistance();
int rghtdft = 30 - sensorRight.getDistance();
dValsouth = dValsouth + lftdft;
dValnorth = dValnorth + rghtdft;
//Average of readings
dValsouth = dValsouth / 20;
dValnorth = dValnorth / 20;
//Assign to Global Variable
Avgleftdeflect = dValsouth;
Avgleftdeflect = dValnorth;
// wait for a Bluetooth® Low Energy central
BLEDevice central = BLE.central();
// if a central is connected to the peripheral:
if (central) {
Serial.print("Connected to central: ");
// print the central's BT address:
Serial.println(central.address());
// turn on the LED to indicate the connection:
digitalWrite(LED_BUILTIN, HIGH);
// check the battery level every Minute = 60,000 milliseconds
// while the central is connected:
while (central.connected()) {
long currentMillis = millis();
// Update OLED Display evey 2 seconds (2000 milliseconds).
if (currentMillis - displayPrevious >= oledDelay) {
displayPrevious += oledDelay;
oledUpdate();
//Update Tablet Data with Sensor readings every Minute
if (currentMillis - previousMillis >= blueLEDelay) {
previousMillis += blueLEDelay;
updateSensorData();
// when the central disconnects, turn off the LED:
digitalWrite(LED_BUILTIN, LOW);
Serial.print("Disconnected from central: ");
void updateSensorData() {
//Assign data call to outputs map to range
int sEdge = Avgleftdeflect;
int nEdge = Avgrightdeflect;
int southLevel = sEdge;
int northLevel = nEdge;
if (southLevel != southEdge || northLevel != northEdge) { // if the Edge deflection has changed
Serial.print("South Edge Deflection is now: "); // print to Serial Monitor
Serial.println(southLevel);
Serial.print("North Edge Deflection is now: "); // print to Serial Monitor
Serial.println(northLevel);
southIRSensorChar.writeValue(southLevel); // and update IR Sensor characteristics
northIRSensorChar.writeValue(northLevel);
southIRSensorChar.broadcast(); //Broadcast updated data values to tablet
northIRSensorChar.broadcast();
southEdge = southLevel; // save the delfection Values for next comparison
northEdge = northLevel;
void oledUpdate() {
//Convert Data to Text
Ldis = String(Avgleftdeflect);
rightDistance = String(Avgrightdeflect);
//Ouput to OLED Display
display.fillScreen(BLACK); //Clear Screen operation
display.setTextColor(WHITE, BLACK); //Set Screen Colour Scheme
display.setTextSize(2); //Set the Text Size
display.setCursor(0, 0); //Cursor Starting Position Line One.
display.print("South Edge");//Display Film left Edge Slack.
display.setCursor(0, 25);
display.print(Ldis);
display.setCursor(0, 40);
display.print("cm +/- 1cm");
display.drawLine(0, 55, 128, 55, WHITE); //Draw Screen Devider line.
display.setCursor(0, 60);
display.print("North Edge"); //Display Film Right Edge Slack
display.setCursor(0, 80);
display.print(rightDistance);
display.setCursor(0, 95);
