BLUETOOTH OBDII / ELM GIVING DUPLICATING DATA RESPONSES
I a HC-05 connected to an Arduino’s Serial 3.
I have also been able to successfully pair with an OBD2-ELM adapter in the car,
I have a code in my sketch to do simple communications with the OBD/ELM
if (Serial3.available()) {
    Serial.write(Serial3.read());
if (Serial.available()) {
    Serial3.write(Serial.read());
The challenge is this:
If I type ATZ, I get “ELM327 v2.1>”, I type ATTP5, I get “OK>”, Typing ATRV, returns “12.6”
But if I type 0105 I get different responses such as: “LM327410v2 ELMv241 M2.11099”, or “OK>LM7v41A” or "OK> OK > 41055.1 327v"
Other times I get the correct response of "4105 5A >"
I get the same result when I type in 0100 or any other PID code.
Please does anyone have an idea as to what might be causing this and how to fix it.
Thanks
serial_monitor_output.txt (19.6 KB)
