Hello,
I'm experiencing a problem when pairing the HC-05 with the ELM327 Bluetooth module. I've connected the HC-05 in AT mode using 3V, and I'm sending the following commands for pairing:
- AT+RESET
- AT+ORGL (Set to original)
- AT+ROLE=1 (Set to Master)
- AT+CMODE=0 (Set connect to a specific address)
- AT+BIND=1234,56,789c72
- AT+INIT (Need to connect)
- AT+PAIR=1234,56,789c72,20 (
,20means a 20-second timeout) - AT+LINK=1234,56,789c72
I’m not receiving any response to the last three commands, and the connection isn’t being established.
Has anyone encountered a similar issue or have any suggestions on what might be causing this problem? Could it be related to the pairing commands, wiring, or something else?
