so… this is the sketch that i am trying to use to switch a relay on or off with bluetooth via ArduDroid but i keep getting an error compiling
expected } at the end of input
now it is probably because i am incredibly tired but i just cant see it.
anyone shed some light?
Thanks!!
heres the sketch
char val; // variable to receive data from the serial port
int ledpin = 2; // LED connected to pin 2 (on-board LED)
pinMode(ledpin = 2, OUTPUT); // pin 2 (on-board LED) as OUTPUT
pinMode(ledpin = 3, OUTPUT); // pin 3 (on-board LED) as OUTPUT
Serial.begin(9600); // start serial communication at 115200bps
if ( Serial.available() ) // if data is available to read
val = Serial.read(); // read it and store it in ‘val’
if ( val == ‘a’ ) // if ‘a’ was received led 2 is switched off
digitalWrite(ledpin = 2, HIGH); // turn Off pin 2
if ( val == ‘A’ ) // if ‘A’ was received led 2 on
digitalWrite(ledpin = 2, LOW); // turn ON pin 2
if ( val == ‘b’ ) // if ‘b’ was received led 3 is switched off
digitalWrite(ledpin = 3, HIGH); // turn Off pin 3
if ( val == ‘B’ ) // if ‘B’ was received led 3 on
digitalWrite(ledpin = 3, LOW); // turn ON pin 3
} //else (ledpin = 3, LOW) //set led pin 3 to low state
if ( val == ‘C’ ) // if ‘C’ was received led 2 on for 1 second
delay(1000); // wait 1 second
digitalWrite(ledpin, HIGH); // turn Off pin 2
if ( val == ‘D’ ) // if ‘D’ was received led 3 on for 1 second
digitalWrite(ledpin, HIGH); // turn Off pin 3
if ( val == ‘E’ ) // if ‘E’ was received led 2 on for 5 seconds
delay(5000); // wait 500 milli seconds
if ( val == ‘F’ ) // if ‘F’ was received led 3 on for 5 seconds
if ( val == ‘G’ ) // if ‘G’ was received turn led pin 2 on for 500ms then switch off and turn on pin 3 for 500 mili seconds then off
delay(500); // wait 500mili second
digitalWrite(ledpin = 3, LOW); // turn ON pin 2
delay(500); // wait 500 mili second
if ( val == ‘h’ ) // if ‘h’ was received switch off all pins
digitalWrite(ledpin = 13, LOW); // turn Off pin 13
if ( val == ‘H’ ) // if ‘H’ was received switch pin 2 on and off 1000 times
for (int i = 0; i < 1000; i++)
digitalWrite(ledpin = 2, HIGH); // turn ON pin 2
delay (1000); //wait 1000 mili seconds
digitalWrite(ledpin = 2, LOW); // turn Off pin 2
