Bluetooth Robot Read question
In the Bluetooth program we can use two programming option as following
I am not posted all the code here , Only related my question
What is the best option from the following two method , Elaboration is highly appreciated
Method 01
Hear serial read " if statement " closed once read is completed
char in;
  if (Serial.available() > 0)
    in = Serial.read();
  }// if statement closed here
  switch (in)
    case 'X':
    case 'x':
Method 02
Below code serial read " if statement " closed end of the switch statement
char in;
    in = Serial.read();
    switch (in)
      case 'X':
      case 'x':
Do you want the switch structure to execute every time loop() runs or execute the switch structure only upon receiving something from serial?
Based on what I see, the switch should run only on reception of new serial data. The in variable can't change outside the serial reception (that I can see).
If the in variable can also change outside the serial reception, execute the switch each time through loop().
Yes I got your point ,
Suppose completed codes use for control the hobby robot , Then at the method 01 motor rotating speed is much more speed than the method 02
Any advice
Sorry, I do not know what that means.
The both method that I point out in my first post can be used drive the robot using following code
But when I apply fist method the robot speed is much speed than the second method
#include <Servo.h>
Servo axis_one;
Servo axis_two;
Servo axis_three;
Servo axis_four;; //0 30
unsigned int axis_one_ctr = 90;//90
unsigned int axis_two_ctr = 130; // min70 , max150
unsigned int axis_three_ctr = 110;//
unsigned int axis_four_ctr = 0;
unsigned int x = 20;
unsigned int y = 50;
char in;
unsigned long lgUpdateTime; //was unsigned int
  axis_one.attach(8);
  axis_two.attach(9);
  axis_three.attach(10);
  axis_four.attach(13);
  axis_one.write(axis_one_ctr);
  axis_two.write(axis_two_ctr);
  axis_three.write(axis_three_ctr);
  axis_four.write(axis_four_ctr);
  lgUpdateTime = millis();
  //while(1);
  //Excute loop every 20 milliseconds, faster than the App sends to avoid buffer over-run
  if ((millis() - lgUpdateTime) > 20)
      in = Serial.read();
      Serial.println(in);
      switch (in)
        case 'X':
          axis_one_left();
        case 'x':
          axis_one_right();
        case 'Y':
          axis_two_forward();
        case 'y':
          axis_two_backword();
        case 'Z':
          axis_three_forward();
        case 'z':
          axis_three_backword();
        case 'O':
          axis_two_ctr = 1;
          axis_two_forward();
        case 'C':
          axis_two_ctr = 0;
        case 'S':
          //do something;
  // Serial.println('S');
void axis_one_right()
  axis_one_ctr++;
  // Serial.println("Come");
  if (axis_one_ctr > 170)
    axis_one_ctr = 170;
void axis_one_left()
  axis_one_ctr--;
  //Serial.println("Come");
  if (axis_one_ctr < 10)
    axis_one_ctr = 10;
void gripper_open() {
void gripper_close() {
void axis_two_forward()
  axis_two_ctr++;
  if (axis_two_ctr > 150)
    axis_two_ctr = 150;
void axis_two_backword()
  axis_two_ctr--;
  if (axis_two_ctr < 70)
    axis_two_ctr = 70;
void axis_three_forward()
  axis_three_ctr++;
  if (axis_three_ctr > 175)
    axis_three_ctr = 175;
void axis_three_backword()
  axis_three_ctr--;
  if (axis_three_ctr < 90)
    axis_three_ctr = 90;
