Bluetooth RX and TX
You can choose two pins from Arduino D0 to D7 as Software Serial Ports to communicate with Bluetooth Shield (D0 and D1 is Hardware Serial Port)
Source: http://www.seeedstudio.com/wiki/Bluetooth_Shield
Besides which pins they operate on, what is the difference between a Software Serial Port and a Hardware Serial Port?
Speed, reliability, and how much they interfere with the other things your program is doing.
When SoftwareSerial detects that serial data is incoming, it blocks until the whole byte arrives. HardwareSerial only blocks until the bit arrives.
Depending on what else your program is doing, that may, or may not, make a difference.
What is the difference between I2C and UART? Is that asking the same question as above in different text? How do I know when to choose between SPI and I2C?
About the same as the difference between a tennis shoe and an elephant. That is they serve completely different purposes.
I2C is inter-chip communication. UART is for communicating with an external device.
You look at the device you want to communicate with. If it is a I2C device, SPI makes no sense. If it is a SPI device, I2C makes no sense.
