hey there,
i try to setup a hc-06 bluetooth modul. For this i connected the RXD(bt modul) to TX(arduino) and the TXD(bt modul) to RX (arduino). The other two pins are in 5V and gnd.
in the arduino software i just tried to print the input value. So it the code looks like this:
int state;
if (Serial.available()){
state = Serial.read();
Serial.println(state);
Now the problem is that the bluetooth modul outputs only the number 35. So the state is always 35... no metter what i send to the modul.
Can you please help me?
Thank yoU!
Try this
/* This is a simple test for two way traffic via bluetooth
but you can try it first using the USB cable to the serial
monitor without the bluetooth module connected.
Note that some bluetooth modules come set to a different baud rate.
This means you need to alter the command
Serial.begin(9600) accordingly
Same goes for the setting in the bottom right corner on the
serial monitor */
String readString;
char c;
pinMode(0, INPUT_PULLUP);// only needed for JY-MCUY v1.06?
Serial.println("OK then, you first, say something.....");
Serial.println("Go on, type something in the space above");
Serial.println(" and hit Send or Enter,");
Serial.println("then I will repeat it!");
Serial.println("");
while (Serial.available()) //Check if there is an available byte to read
delay(3); //Delay added to make thing stable
c = Serial.read(); //Conduct a serial read
readString += c; //build up the string
} // end while
if (readString.length() >0)
Serial.write(c);
readString="";
} // end if
note the Serial.write(c);
