Bluetooth sending and receiving two Bytenumber?
I am testing the link sketch works well.
https://create.arduino.cc/projecthub/anova9347/control-your-robot-with-your-phone-joysticks-app-a4ab50
Seems the receiver can't receive two Bytenumber? like the picture 1 below, if modified as picture 2, that can't be received, no matter which picture, 31 no work, why?
Thanks
Adam
#include <TimedAction.h> //this library is outdated and it won't work with the newest versions of Arduino. After you downloaded the library - https://playground.arduino.cc/Code/TimedAction/ - you must open the libraries folder, open the TimedAction folder, open the TimedAction.h file and change the 33/34 line (from #include "TimedAction.h" to #include "Arduino.h"). If it is already changed, then you shouldn't have any problems.
#include <Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
Servo myservo4;
int val,cnt=0,v[4];
int pos1=90,pos2=90,pos3=90,pos4=90;
int val1,val2,val3,val4;
int timer1,timer2,timer3;
int Ok1=1,Ok2=1,Ok3=1;
int delayy2,delayx1,delayy1;
void readbt() {
    val=Serial.read();
    cnt++;
    v[cnt]=val;
    if(v[1]==1 && cnt==3) {
      cnt=0;
    if(v[1]!=1 && cnt==2) {
      cnt=0;
void program() {
  timer1++;
  timer2++;
  timer3++;
TimedAction readbtThread = TimedAction(10,readbt);
TimedAction timerThread = TimedAction(1,program);
  myservo1.attach(9);
  myservo2.attach(10);
  myservo3.attach(11);
  myservo4.attach(6);
  if(Serial.available()) {
      while(Serial.available() == 0);
      readbtThread.check();
      timerThread.check();
      if(v[1]==1) {
        Ok1=0;
        val1=v[2];
        val2=v[3];
      if(v[1]==2) {
        Ok2=0;
        val3=v[2];
      if(v[1]==3) {
        Ok3=0;
        val4=v[2];
  joystick1();
  joystick2();
  slider();
void joystick1() {
  if (Ok1==0) {
    if(v[1]==1 && (v[2]==100 && v[3]==100)) {
      Ok1=1;
    if(val1>100 && pos1<180) {
      delayx1=((200-val1))+15;
      if(timer1>=delayx1) {
        pos1++;
        myservo1.write(pos1);
        timer1=0;
    if(val1<100 && pos1>0) {
      delayx1=val1+15;
        pos1--;
        timer1=0;
    if(val2>100 && pos2<180) {
      delayy1=((200-val2))+15;
      if(timer2>=delayy1) {
        pos2++;
        myservo2.write(pos2);
        timer2=0;
    if(val2<100 && pos2>0) {
      delayy1=val2+15;
        pos2--;
        timer2=0;
void joystick2() {
  if (Ok2==0) {
    if(v[1]==2 && v[2]==100) {
      Ok2=1;
    if(val3>100 && pos3<180) {
      delayy2=((200-val3))+15;
      if(timer3>=delayy2) {
        pos3++;
        myservo3.write(pos3);
        timer3=0;
    if(val3<100 && pos3>0) {
      delayy2=val3+15;
        pos3--;
        timer3=0;
void slider() {
  if(Ok3==0) {
    if(pos4==val4) Ok3=1;
    if (val4>pos4) {
      for(int i=pos4;i<=val4;i++) {
        myservo4.write(i);
        delay(15);
    if(val4<pos4) {
      for(int i=pos4;i>=val4;i--) {
        myservo4.write(i);
        delay(15);
    pos4=val4;
mit.1
mit.2
See the serial input basics tutorial.
