i am making a weatherstation and it's suppoused to measure temperature, pressure and humidity. The measurements work fine and when i am getting them on the serial monitor with cable it also works fine. When i try to recieve the infos from a HC-06 bluetooth module all i get are some strange symbols. Can anyone help me rewrite the code or do something so the weatherstation funktions with the bluetooth like it should be.
In order to help with a coding problem we kind of need to see the code. Are you sure that it is not a hardware problem (mismatched baud rates, for instance)? Please post the data before and after being sent so that we can see what is happening.
Please read the "how to use the forum" Stickies to see how to format and post code. And some hints on how to ask an effective question.
Here is the code:
#include <Wire.h>
#include <dht.h>
#define dht_apin A3
#define lightPin A1
int brightness;
dht DHT;
brightness = 0;
DHT.read11(dht_apin);
brightness = analogRead(lightPin);
Serial.print("| Temperature: ");
Serial.print(DHT.temperature);
Serial.print(" C");
Serial.print(" ");
Serial.print("Humidity: ");
Serial.print(DHT.humidity);
Serial.print(" % ");
Serial.print(" ");
Serial.print("Brightness: ");
Serial.print(brightness);
Serial.println(" |");
delay(5000);
The bluetooth is hooked up properly, i tried changing the baud rate, but it doesn't work with several values.
Please provide a block diagram or schematic of how your project is wired. Which Arduino are you using? Is the hardware serial (pins 0 and 1) connected to the bluetooth device and serial monitor at the same time?
Hallo. I am making a small weatherstation project based on Arduino Uno. I have the following problem:
Using the cable everything is ok - the information is sent via Serial Port and everything works fine.
When i hook up the HC-06 Bluetooth module it starts to send some funny characters to the Serial port or nothing at all. With my new PC there are 3 Serial Ports available after connecting the HC-06 to the PC Bluetooth and none of them recieves information from the Arduino. I've been told to change the baud rate and try again but it doesent work also.
I am asking for advice now - how can i solve the problem and get the weatherstation working with the Bluetooth module?
iliyaniliev57:
That is a baud issue.
Can you post your code and a schematic of your setup?
Is this related to this thread?
https://forum.arduino.cc/index.php?topic=483101.msg3297307#msg3297307
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom..
This is the schematic. I think it is right wired. Up in the topic is the code. I really don't know where the problem is.
Please read http://forum.arduino.cc/index.php/topic,148850.0.html
Attach your schematic as a jpg, png or pdf file.
Thanks.. Tom..
