I am trying to do Bluetooth serial communication using two hc05, I have made one as master (by assigning the role as 1) and other as a slave ( role = 0). By using the AT+BIND command I have paired them. Now i am trying to send data using the serial monitor of master and want to read the same msg at the serial monitor of slave, but I am only getting (-1) on the receiver side.
Which Arduino ?
Which sketch ? use code tags ( </> ) to post it please.
BTW I doubt if thats alll yous sketch's contains that it will work as you are simply trying to read at the PC end not the BT points.
