Bluetooth Serial HC-05 on base board and Mac OSX not connecting.
Hi All,
I'm having trouble connecting my Arduino UNO (smd edition) with Bluetooth HC-05 attached via the base board to my Mac book via bluetooth.
This is the HC-05 package I'm using: http://www.ebay.ie/itm/171151364998?var=470296354519&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Upon entering into the "Set Up Bluetooth Device" menu I can select the HC-05 device. The "Setup Assistant" then attempts to pair with the device and succeeds (1234 device code). After this though the HC-05 does not appear on my Bluetooth Devices list.
The HC-05 LED slows down (indicating connection I believe), but is there a way to verify that there is an actual connection made on the laptop?
Most confused :~
Can anybody help this out? I’m also struggling with the same issue.
