Bluetooth serial readings on 0.96'' Adafruit OLED
Hello ,
I am trying to display the readings of LDR connected to slave arduino through serial monitor of master arduino paired with bluetooth. I got the readings and it is working fine.
But when I connected OLED to the master arduino so that the LDR readings can be displayed on OLED as well as serial monitor, it is not displaying as expected.
So for simplicity I tried sending the word "hello" from slave to master. The code for slave is :
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(10, 11); // RX | TX
  pinMode(9, OUTPUT);  // this pin will pull the HC-05 pin 34 (key pin) HIGH to switch module to AT mode
  digitalWrite(9, HIGH);
  BTSerial.begin(9600);
  BTSerial.println("hello");
Then I tried displaying the same only on serial monitor of master. The code:
char state ;
 Serial.println("<Arduino is ready>");
 if (BTSerial.available()) {
   state = BTSerial.read();
   Serial.write(state);
It is showing valid readings in serial monitor with hello being printed after every one second
<Arduino is ready>
hello
hello
hello
hello
But when I modified the code so that I can get the readings on OLED as well as serial monitor;
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
char sensor;
  Wire.begin();
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);// initialize with the I2C addr 0x3C (for the 128x32)(initializing the display)
void displayreading()
   if (BTSerial.available()) //checks for incoming data
      sensor = BTSerial.read();//reads data from bluetooth serial
      display.clearDisplay();
      display.setTextColor(WHITE);
      display.setCursor(30,0);
      display.setTextSize(1);
      display.print("LDR Reading:");
      display.setCursor(30,10);
      display.setTextSize(2);
      display.print(sensor);
      Serial.write(sensor);
    displayreading();
    display.display();
The OLED is showing one letter at a time clearing the screen after every letter rapidly (since I did not add delay which will add up to the problem of data lag). Like :
h , (clear screen)
e (clear screen)
l (clear screen)
l (clear screen)
0 (clear screen)
The serial monitor is showing the readings as:
<Arduino is ready>
hello
hello
hello
hello
But the word hello is printed letter after letter and not in a whole like in the previous master code.There is one second gap after every printing of "hello".
Can someone please help me with this problem?
Thanks in advance
