Bluetooth Shield does not read, but can send
I am using this Arduino Bluetooth Shield from Seeedstudio. I used their example code and connected it with my phone. On my phone I can read the AT commands that the shield sends, but when I send something and print it in the serial monitor it does not receive. blueToothSerial.available() stays 0.
Is my shield broken? Or is my code below wrong?
#include <SoftwareSerial.h>   //Software Serial Port
#define RxD 7
#define TxD 6
#define DEBUG_ENABLED  1
#define PIN_TEMP    A5
SoftwareSerial blueToothSerial(RxD,TxD);
int getTemp()
    int a = analogRead(PIN_TEMP);
    int B=3975;
    float resistance = (float)(1023-a)*10000/a;
    float temperature = temperature=1/(log(resistance/10000)/B+1/298.15)-273.15;
    return (int)temperature;
    pinMode(RxD, INPUT);
    pinMode(TxD, OUTPUT);
    setupBlueToothConnection();
    char recvChar;
    while(1)
        if(blueToothSerial.available())
        {//check if there's any data sent from the remote bluetooth shield
            recvChar = blueToothSerial.read();
            Serial.print(recvChar);
            blueToothSerial.print(recvChar);
            if(recvChar == 't' || recvChar == 'T')
                blueToothSerial.print("temperature: ");
                blueToothSerial.println(getTemp());
        if(Serial.available())
        {//check if there's any data sent from t he local serial terminal, you can add the other applications here
            recvChar  = Serial.read();
void setupBlueToothConnection()
	blueToothSerial.begin(9600);
	blueToothSerial.print("AT");
	delay(400);
	blueToothSerial.print("AT+DEFAULT");             // Restore all setup value to factory setup
	delay(2000);
	blueToothSerial.print("AT+BAUD4");
	delay(400);
	blueToothSerial.print("AT+NAMESeeedBTSlave");    // set the bluetooth name as "SeeedBTSlave" ,the length of bluetooth name must less than 12 characters.
	delay(400);
    blueToothSerial.print("AT+PIN0000");             // set the pair code to connect
	delay(400);
	blueToothSerial.print("AT+AUTH1");             //
    delay(400);
    blueToothSerial.flush();
I thought your code is junk, but I saw this
http://forum.arduino.cc/index.php?topic=320606.new#new
I still think it's junk, but it might not be, and I know it isn't down to you.
