Bluetooth sound to selectabe speakers from Arduino uno R3
Hi All
First Post.
Equipment :- UNO R3 surface mounted chip, BT transmitter, BT receivers (Bluetooth), Speakers
The project is a model train control with Bluetooth sound to the train.
There will be a maximum of 2 trains operating a one time, but there will be several trains available, each with its own speaker and its own sound characteristics.
Q1....Firstly, is it possible to have a single BT transmitter and several select-able independent BT receivers to drive a selected speaker ?
Q2....If so, what Bluetooth equipment is suitable for this ?
Q3....Are BT speakers select-able, ie say 3 speakers turned on but only 1 will accept the sound. This or similar is what i plan to use if suitable.
http://www.ebay.com.au/itm/111807745435?_trksid=p2055119.m1438.l2648&var=410794794532&ssPageName=STRK%3AMEBIDX%3AIT
I have already developed the Train Controller with full features and still have 5 digital and 4 analog pins available, there will be a smart 1602 screen added when it arrives. Once tested, i will be happy to post results in the appropriate forum, let me know which.
I have added a Youtube link showing the general concept here :-
Arduino + WAV Trigger = LocoSound Prototype - YouTube .
This shows some equipment , but i am looking for other options also.
Unfortunately this and similar projects seem to have died or been kept private. There may be a reason for this.
Enough for this post
Thanks in advance
Doug :slight_smile:
Q1 - no
Q2 - not applicable
Q3 - no
Basically you can not transmitt sound through a Uno and a Bluetooth add on board as it does not support the audio protocol.
Thanks Mike
New approach...directional speakers in the hand controller run off a DFPlayer mini, not a sweet as DCC but in an enclosed room it should be suitable, from what i have seen the delay between tracks is so small as not to be a problem, will find out for sure when player and other bits arrive in post.
Doug
:slight_smile:
