Bluetooth switchChrachtaristic not working. what am I screwing up I'm new.
I am able to see Rocket under bluetooth using nRF however the charactaristic shows as unknown service not esspresso service. does not route to the switchCharacteristicWritten function. Its like it is never called. i am sending uint8 1 with nRF. Thanks!
#include <Arduino.h>
#include <ArduinoBLE.h>
const int  buttonPin = 13;    // the pin that the pushbutton is attached toes
const int espressoPin = 12;       // the pin that the LED is attached to
bool on; // boolean to keep track of on/off
int timer = 0; //counts how long the button is pushed
BLEService esspressoService("fe8e9fb9-e229-4df3-975d-8b92b7a31c9c");
BLEByteCharacteristic switchCharacteristic("fe8e9fb9-e229-4df3-975d-8b92b7a31c9c", BLERead | BLEWrite);
// central connected event handler
void blePeripheralConnectHandler(BLEDevice central) {
  Serial.print("Connected event, central: ");
// central disconnected event handler
void blePeripheralDisconnectHandler(BLEDevice central) {
  Serial.print("Disconnected event, central: ");
  Serial.println(central.address());
void switchCharacteristicWritten(BLEDevice central, BLECharacteristic characteristic) {
  // Setup wifi disconnect bluetooth
  Serial.print("Characteristic event, written: ");
  if (switchCharacteristic.value()) {
    Serial.println("LED on");
    digitalWrite(espressoPin, HIGH);
    Serial.println("LED off");
    digitalWrite(espressoPin, LOW);
  while (!Serial);
  pinMode(espressoPin,OUTPUT);
  pinMode(buttonPin,INPUT);
  if (!BLE.begin()) {
    Serial.println("starting BLE failed!");
    while (1);
  // set the local name peripheral advertises
  BLE.setLocalName("Rocket");
  // set the UUID for the service this peripheral advertises
  BLE.setAdvertisedService(esspressoService);
  // add the characteristic to the service
  esspressoService.addCharacteristic(switchCharacteristic);
  BLE.addService(esspressoService);
  BLE.setEventHandler(BLEConnected, blePeripheralConnectHandler);
  BLE.setEventHandler(BLEDisconnected, blePeripheralDisconnectHandler);
  // assign event handlers for characteristic
  switchCharacteristic.setEventHandler(BLEWritten, switchCharacteristicWritten);
  // set an initial value for the characteristic
  switchCharacteristic.setValue(0);
  BLE.advertise();
    // read the pushbutton input pin:
  BLE.poll();
  if (digitalRead(buttonPin) == HIGH)
      // start a counter
    while (digitalRead(buttonPin) == HIGH)
        timer++;
      // if it is less than 5000 ms turn on /off machine else start bluetooth pairing
    if(timer >= 5)
      // start pairing
      Serial.println("Pairing");
      BLE.advertise();
      Serial.println("Bluetooth device active, waiting for connections...");
      //  if timer is less than 5 ms check to see if espressoPin is high or low
      //  if it's low turn it on
    else if(!on)
      on = true;
      digitalWrite(espressoPin,HIGH);
      Serial.println("ON");
      // if its high pull it low
    else if(on)
      on = false;
      digitalWrite(espressoPin,LOW);
      Serial.println("OFF");
    // reset timer
    timer = 0;
Your service and characteristic have the same UUID. They need to be different.
