Bluetooth transfer rate
Hello, I am trying to send a txt file with different voltage values (that was taken from a sensor) to an android device. Currently my txt file is 3.3Mbs and it takes me about 1 hour to transfer that data. I am using an Arduino Uno, ethernet shield (for the sdcard part), bluetooth shield ( i have both the HC-05 and HC-06) and I am using the android app called Blueterm to test all of this. So, my questions are:
Why does it take this long to transfer the data?
How can I speed up the time it takes to transfer the data?
Will changing the bluetooth’s baudrate make a difference?
If I were to use a Arduino Mega would I get better results?
Here is my code:
#include <SoftwareSerial.h>
#include <SD.h>
int state = 0;
int flag = 0;      //Makes sure that it doesnt keep reading the file after closing it
int Tx = 2;         // Connect the Bluetooth Rx to this pin
int Rx = 3;         // Connect the Bluetooth Tx to this pin
File Datafile;
SoftwareSerial bluetooth(Rx,Tx);
    // sets the pins as outputs:
    pinMode(ledPin, OUTPUT);
    digitalWrite(ledPin, LOW);
    bluetooth.begin(9600); // Default connection rate for my BT module
    pinMode(10,OUTPUT);     //For the pin set up reffer to Gammas code
    digitalWrite(10,HIGH); //For my own purposes..
    //if some data is sent, read it and save it in the state variable
    if(bluetooth.available() > 0)
      state = bluetooth.read(); //listens to the android device for an input
    flag = 0;
    // if the state is 1 data will be sent to the android device
    if (state == '1')
        if (flag == 0)
            bluetooth.println("testing text");
            sdreader();
            flag = 1;
void sdreader()
    bluetooth.print("Initializing SD Card....");
    if (!SD.begin(4))
        bluetooth.println("initialization failed!");
        return;
    bluetooth.println("initialization done.");
    Datafile= SD.open("1.TXT");      //Change the file name to the file your using
    if (Datafile)
        bluetooth.println("1.TXT");
        while (Datafile.available())
            bluetooth.write(Datafile.read());   //Reads the file line by line and sending it to the bluetooth device.
        Datafile.close();
        bluetooth.println(millis());
        bluetooth.println("error opening DATALOGH.TXT");
Because you have a lot of data and are sending it out very slowly.
Send less data or send it faster. Nothing magic.
Will changing the bluetooth's baudrate make a difference?
Isn't that obvious?
Not without making code changes.
I tried changing the Baud rate using this tutorial and after I got the bluetooth shield in AT command mode I wasn't able to send or receive information from the bluetooth. The last thing i saw in the serial monitor was the baud rate changing to 115200. After changing the baud rate in my code I was not able to send information anymore. Same thing occurred to my HC-06 shield after putting it in AT command mode. I have tried changing it back to 9600, but was not able to successfully send the "AT+BAUD4" command, or any AT command for that matter. Is there a way for me to change the baud rate without using the arduino?
