BluetoothMate as datapipe for UNO
Hi All,
EDIT: TL,DR version - I think the question I should be asking is.. How do I tell my Uno sketch to recognise and transmit data through the BluetoothMate serial port when a connection is made?
THE DETAILS I have successfully hooked up a BluetoothMate Gold to my Uno. connected my Arduino IDE to it via bluetooth, used serial monitor to enter command mode and explored the present settings of the BluetoothMate Gold. I wired the boards according to the diagram halfway down this page, and followed these instructions and the advanced guide to bluetooth.
However, I am not able to get the UNO sketch to run and send data via the BluetoothMate Gold to my serial monitor. I am running this sketch on the UNO:
 Bluetooth test program
int counter = 0;
int incomingByte;
  // see if there's incoming serial data:
  if (Serial.available() > 0) {
    // read the oldest byte in the serial buffer:
    incomingByte = Serial.read();
    // if it's a capital R, reset the counter
    if (incomingByte == 'R') {
      Serial.println("RESET");
      counter=0;
  Serial.println(counter);
  counter++;
  delay(250);
When I use the UNO's serial port via USB I open serial monitor and see the counter working. I can send it 'R' and the counter resets. Also, the UNO's tx LED blinks as data is sent. Fine.
When I select the BluetoothMate Gold's serial port and open the serial monitor the bluetooth connection is made but the UNO's tx LED stops blinking (so I presume the sketch stops running) and no data is piped through.
What am I missing? Why isn't my BluetoothMate Gold acting as a datapipe? Do I need to add something to the sketch loaded on the UNO?
All help is much appreciated.
Nick
I am an Arduino newbie using:
13" MacBook Pro (mid 2010), OSX 10.9.5 Mavericks. Arduino IDE 1.0.6 Arduino UNO BluetoothMate Gold
