I'm using ESP32 Arduino IDE. I have one task at each core. In the core0 task I set up a timer interrupt that signals to the task (through the interruptCounter variable) to toggle a pin every 100 us. On core1 I have a task which sends some gibberish on bluetooth with the SerialBT.println("1") function.
I measured the pin with an oscilloscope. If I delete SerialBT.println("1") function, or use Serial.println("1"), or I don't open the bluetooth serial monitor on Arduino IDE, it works fine and I get a nice 5 kHz square signal. However, if I open the serial monitor on the port associated with bluetooth, the pin toggles at very random intervals, so the frequency changes all the time.
I tried many things, but I still have no idea how one core affects the other in this code.
EDIT: After finding the run/stop button on the oscilloscope, I realised that it still mostly toggles at a regular 100us interval, but every after every few toggle it forgets to toggle for a few ms usually. The interval and the pulses between these glitches seem to be irrergular. So the problem remains, but I just added this info.
#include "BluetoothSerial.h"
#include "esp_task_wdt.h"
volatile int interruptCounter = 0;
hw_timer_t * timer = NULL;
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;
BluetoothSerial SerialBT;
//interrupt routine
void IRAM_ATTR onTimer() {
portENTER_CRITICAL_ISR(&timerMux);
interruptCounter++;
portEXIT_CRITICAL_ISR(&timerMux);
Serial.begin(2000000);
SerialBT.begin("ESP32"); //Bluetooth device name
Serial.println("The device started, now you can pair it with bluetooth!");
pinMode(26, OUTPUT);
disableCore0WDT();
disableCore1WDT();
xTaskCreatePinnedToCore(
adc_read, /* Function to implement the task */
"adc_read_task", /* Name of the task */
1024, /* Stack size in words */
NULL, /* Task input parameter */
1, /* Priority of the task */
NULL, /* Task handle. */
0); /* Core where the task should run */
bl_send, /* Function to implement the task */
"bl_send_task", /* Name of the task */
2, /* Priority of the task */
1); /* Core where the task should run */
void loop() {vTaskDelete(NULL); }
static void adc_read (void *pvParameters )
//launch the interrupt on core 0
timer = timerBegin(0, 80, true);
timerAttachInterrupt(timer, &onTimer, true);
timerAlarmWrite(timer, 100, true);
timerAlarmEnable(timer);
for(;;) {
if (interruptCounter > 0) {
portENTER_CRITICAL(&timerMux);
interruptCounter=0;
portEXIT_CRITICAL(&timerMux);
digitalWrite(26, !digitalRead(26));
static void bl_send (void *pvParameters )
for( ;; )
SerialBT.println("1");
