I'm working on an hobby project to communicate bluetooth device (ELM327), using Elmduino library GitHub - PowerBroker2/ELMduino: Arduino OBD-II Bluetooth Scanner Interface Library for Car Hacking Projects, this library requires Bluetoothserial.h, as far as i understand that library part of ESP32 board, so i've installed ESP32 to arduino ide through this tutorial https://github.com/espressif/arduino-esp32/blob/master/docs/arduino-ide/boards_manager.md, and when i try to run this code;
#include "BluetoothSerial.h"
#include "ELMduino.h"
BluetoothSerial SerialBT;
#define ELM_PORT SerialBT
#define DEBUG_PORT Serial
ELM327 myELM327;
uint32_t rpm = 0;
#if LED_BUILTIN
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
#endif
DEBUG_PORT.begin(115200);
SerialBT.setPin("1234");
ELM_PORT.begin("OBDII", true);
if (!ELM_PORT.connect("OBDII"))
DEBUG_PORT.println("Couldn't connect to OBD scanner - Phase 1");
while(1);
if (!myELM327.begin(ELM_PORT))
Serial.println("Couldn't connect to OBD scanner - Phase 2");
while (1);
Serial.println("Connected to ELM327");
float tempRPM = myELM327.rpm();
if (myELM327.status == ELM_SUCCESS)
rpm = (uint32_t)tempRPM;
Serial.print("RPM: "); Serial.println(rpm);
printError();
void printError()
Serial.print("Received: ");
for (byte i = 0; i < myELM327.recBytes; i++)
Serial.write(myELM327.payload[i]);
Serial.println(F("\tELM_SUCCESS"));
else if (myELM327.status == ELM_NO_RESPONSE)
Serial.println(F("\tERROR: ELM_NO_RESPONSE"));
else if (myELM327.status == ELM_BUFFER_OVERFLOW)
Serial.println(F("\tERROR: ELM_BUFFER_OVERFLOW"));
else if (myELM327.status == ELM_UNABLE_TO_CONNECT)
Serial.println(F("\tERROR: ELM_UNABLE_TO_CONNECT"));
else if (myELM327.status == ELM_NO_DATA)
Serial.println(F("\tERROR: ELM_NO_DATA"));
else if (myELM327.status == ELM_STOPPED)
Serial.println(F("\tERROR: ELM_STOPPED"));
else if (myELM327.status == ELM_TIMEOUT)
Serial.println(F("\tERROR: ELM_TIMEOUT"));
Serial.println(F("\tERROR: ELM_GENERAL_ERROR"));
delay(100);
it returns :
BluetoothSerial.h: No such file or directory
It seems like it's not downloading necessary library when i install ESP32 board to arduino ide, downloaded library from GitHub - espressif/arduino-esp32: Arduino core for the ESP32 and copied arduino-esp32-master folder to arduino's library folder but when i try the run the code it returns :
again, so in the arduino-esp32-master folder, there is libraries folder and there are 27 libraries including BluetoothSerial folder, copied all of them to arduino's library folder, after that when i try run the code it returns:
In file included from C:\Users\FSC\Desktop\SPARKFUN\Bluetooth_ELM327_ILE_CALISAN\ELMduino-master\examples\ESP32_Bluetooth_Serial\ESP32_Bluetooth_Serial.ino:1:0:
C:\Program Files (x86)\Arduino\libraries\BluetoothSerial\src/BluetoothSerial.h:18:10: fatal error: sdkconfig.h: No such file or directory
#include "sdkconfig.h"
compilation terminated.
exit status 1
what am i doing wrong here? how i can install the BluetoothSerial library?
